Old 03-31-2014, 09:05 PM   #1
CARNZ
CHECK ENGINE
Drives: 2004 STi
Post BRZedit recent updates
Figured i'd mention this on here incase any of the BRZedit users don't have the latest update.
Shoot epifan an email at epifansoft@gmail.com if you do not have the most recent version.
I don't think the auto check for update feature works on the BRZedit app, I emailed epifan directly then he told me an update was available (BRZedit 129).
List of new tables, etc in new update:
Code:
brzEdit 129 release
+ New maps:
   MAF Correction After Start (Neutral)
   MAF Correction After Start (In Gear)
   Input A Rising Load Activation ECT Load 1-14
brzEdit 128 release
+ New maps:
   VVT Maps switch - Safe/Normal Threshold
   VVT Exhaust Low RPM Low Load Max
   VVT Intake Low RPM Low Load Max
   VVT High Speed RPM Threshold
   VVT Intake Low RPM Low Load Min
   VVT Low Load RPM Threshold
   VVT Exhaust Low RPM Low Load Min
   Rev Limit Stationary Throttle Close A
   Rev Limit Stationary Throttle Close B
   Hotstart Enrichment Decay Delay
   Hotstart Maximum Non-Idle Enrichment Delay
   Hotstart Minimum Enrichment Limit Runtime
   Overrun Fueling Cut Counter RPM Threshold
   Overrun Enrich RPM Delta Activation
   Overrun Initial Injector Enrichment
   Hotstart High Enrichment Activation Threshold (Coolant)
   Hotstart High Enrichment Activation Threshold (Intake)
   Hotstart Low Enrichment Activation Threshold (Coolant)
   Hotstart Low Enrichment Activation Threshold (Intake)
   Initial Hotstart Enrichment (High)
   Initial Hotstart Enrichment (Low)
   Hotstart Minimum Enrichment (During Delay and Runtime)
   Hotstart Enrichment Decay Step
   Maximum Non-Idle Hotstart Enrichment (Post Delay)
   Overrun Fueling RPM Resume Threshold
   Fuel Map Additive
   Per Injector Pulse Width Compensation A
   Per Injector Pulse Width Compensation B
   Per Injector Pulse Width Compensation C
   Per Injector Pulse Width Compensation D
   Per Injector Pulse Width Compensation E
   Per Injector Pulse Width Compensation F
   Per Injector Pulse Width Compensation G
   Per Injector Pulse Width Compensation H
   Transient Ignition Retard TPS Angle Threshold
   Base Timing Idle (In-Gear)(Above Speed Threshold) B
   Base Timing Idle (In-Gear)(Below Speed Threshold) B
   Base Timing Idle (In-Gear)(Below Speed Threshold) C
   A/F Learning #1 Airflow Ranges B
+ New logger defs including AF Learning infomation
= bug fixes
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 04-22-2014, 12:04 PM   #2
brn12345
brn12345's Avatar
Just updated to 129 and there are a bunch of new tables!!! There is a full folder of tables just dedicated to HOTSTART. This is great news as finally we can look into eliminating the idle drone!!! Suffice to say ill be spending considerable time digging through the updates. Also noticed that there is now a definition for when switching occurs to the safe maps
Thank you Epifan !!!!!
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Navigation updates B-R-Z BRZ First-Gen (2012+) — General Topics 48 11-19-2014 01:19 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
brzEdit Software Updates & Lower Pricing brzEdit Software Tuning 24 10-01-2013 09:21 PM
GPS map updates? (I-69 Indiana) BMWDavid Electronics | Audio | NAV | Infotainment 1 11-30-2012 09:11 AM
aus toy updates website Slide AUSTRALIA 7 12-30-2011 04:20 AM
