Old 10-29-2014, 01:10 PM   #1
blown
Drives: ft86
rear oil seal
anyone have any good tips installing this seal?
blown is offline   Reply With Quote
Old 10-29-2014, 01:39 PM   #2
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Can you share a link to the item you're describing?
JohnJuan is offline   Reply With Quote
Old 10-29-2014, 01:54 PM   #3
blown
Drives: ft86
its also known as the rear main seal. the one between gearbox and motor around the crank.
Old 10-29-2014, 02:25 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Drain oil from the gearbox before you pull the drive shaft.
Remove the top bolts from the bell housing last. Support the transmission on its way out so you don't break shit.
Mark the position of the pressure plate before you remove it.
Make sure you have a clutch alignment tool for the reassembly.
Are the flywheel bolts torque-to-yield? Better check on that. In any case, use a torque wrench for everything.
pre-lube the seal before installing it and be careful not to nick it.
How many miles? What happened?
Old 10-29-2014, 03:10 PM   #5
blown
Drives: ft86
picked up a used motor, figured it would be a good idea to change the seal out since there was some signs of seepage.
more pertaining to installing the new seal would be good tapping it in with a PVC pipe and still popping out on the opposite side.
Old 10-29-2014, 09:16 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
I haven't seen what our rear main looks like but you have to be very careful with all lip seals not to get the sealing lip caught on the shaft as it can roll over and not only will it not seal but the spring can wear a grove in the crank.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Ultramaroon (10-31-2014)
Old 10-29-2014, 09:25 PM   #7
Ultramaroon
not playing cards
no groves on my crank
Turdinator (10-29-2014)
Old 10-30-2014, 12:12 AM   #8
blown
Drives: ft86
no spring in the seal. it sure is difficult trying to get it to go in evenly .. any other suggestions? I'm glad I picked up an extra seal.
Old 10-30-2014, 12:13 AM   #9
Ultramaroon
not playing cards
LOL, I was gonna suggest that.
Hunk of wood and a dead blow hammer?
Old 10-31-2014, 10:12 AM   #10
blown
Drives: ft86
did it using the pvc cap. the trick I learned was to push it in by hand as much as you can evenly, use the cap to lightly tap the raised edges. it helped having an extra set of hands holding the cap.
Old 10-31-2014, 10:29 PM   #11
Ultramaroon
not playing cards
Oh, a cap! That makes perfect sense. I'm going to remember that.
Cool beans!
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
diy taillight gasket seal toby714 DIY (Do-It-Yourself) Guides 1 03-10-2014 11:24 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
the DI seal and popping solution? ft86me Issues | Warranty | Recalls / TSB 91 11-24-2013 07:13 PM
AT Transmission rear seal leaking. CircuitJerk Issues | Warranty | Recalls / TSB 6 10-31-2013 03:41 PM
