| CANADA Canada |
Drives: AE86
Need a shop - Rail & Brake Dust Removal (Hamilton)
Welp I've had my FR-S since they launched in 2012, my car is white, Im noticing the beginning of black specs and some of them turning rust color.
Does anyone know a very good reputable shop that can deal with this? |
Drives: subaru
Why not try it yourself? I run a detailing shop and all you need is a clay bar and 4 hours. Simply wash the car, dry it and clay bar it with any clay bar from Canadian tire. Very simple process and can be done for under $40. Take your time and go slowly over each panel. There is lots of videos available online. At the end if your process just apply wax and your good to go for the winter!
#3 | |
Cliuless
Drives: Whiteout Scion FRS 2014
Drives: AE86
is it really that simple?
I'm terrified of scartching the car |
Drives: subaru
Drives: subaru
Do you own a older car you can test it on first? As long as you take your time and go really slow you will be fine. If you stop by I could show you a test panel on my car and even let you try it out. Its really simple
Drives: SWP BRZ Limited MT
Iron-x
Drives: 2013 Scion FRS
It's a very simple process, but try it on an inconspicuous area first with a halogen light. Use lots of detail spray. Claying will cause some marring on the paint, but that can be removed later with a light polish.
![]() 2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
Are you 20/20?
Drives: Hopes and dreams
#10 |
Dances with Cones
Drives: 2013 Scion FR-S Raven
Don't even use the detailer spray that's included. Just wash the car, give it a quick rinse, and then wash it again, only this time, use the soap as a lubricant for the clay bar. Wipe in one direction with the bar in the soapy mix on the car and do not apply pressure. Continuously fold the bar over so you are using a clean side and work your way around the car until the little specs are gone.
Clay is easy to do. I to used to run a detail shop as well. If washing your car is a 1 out of 10 on the difficulty scale, then this is 1.1. And for those worried about scratching your car...guess what?! You're going to scratch it driving it! Unless it's in a hermetically sealed room all it's life and never driven, it will get dirt on it and it will scratch. The internet detailers these days have scared people into thinking they have to use heavy chemicals to rinse and soap the car and leaf blowers to dry to avoid scratching. Guess what? Air+dirt makes scratches too! So just deal with the inevitable and wash your car regularly like a normal person. Clay from time to time, and give it a little buff at times outside of that to bring it back to life.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
| Parking brake dust cover | Chaetagnath | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 08-29-2014 11:05 PM |
| Brake dust or rail dust? Dealership bs? | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 12-21-2013 09:30 AM |
| brake dust? | Capstan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-13-2012 06:35 PM |
| Brake pad dust | yomchi1989 | AUSTRALIA | 7 | 08-19-2012 01:08 AM |
| Rail dust/clay bar experiences? | chulooz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 05-18-2012 12:10 AM |
