Old 10-28-2014, 01:09 AM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Question Push-Start BRZ Limited?
Anyone know how to push-start a BRZ limited with a dead battery? I've tried looking on the interwebs and haven't found a solution. This of course applies to all manual cars with a keyless ignition.
This is useful information me as well as other members may need someday.
carma143 is offline   Reply With Quote
Old 10-28-2014, 01:15 AM   #2
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
The same way you do with a key-ignition car?
If the battery is so dead that you can't even get the ignition to come on, then I think it might be a lost cause.
I've never had to worry about it, LED interior lights and auto-headlights. The stereo turns off when battery voltage drops. If you have a dead battery, you probably have other issues or neglected the battery itself somehow. Are you asking becaues you have a dead battery? This should be a non-issue..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-28-2014, 02:08 AM   #3
carma143
carma143's Avatar
It's a "what if" question. I don't currently have a dead battery in my car. I just want to know if there is any difference because of a keyless ignition. If there isn't a difference then all the better because then more people know what to do if the cituation ever happens to them.
Old 10-28-2014, 08:34 AM   #4
navanodd
Drives: 2013 BRZ Sport-tech WRB
Assuming there's enough power for electronics and not starter, hit the push start twice without depressing clutch or brake to get the car to the "on" state. From there should be business as usual I would think.
navanodd is offline   Reply With Quote
Old 10-28-2014, 09:14 AM   #5
extrashaky
Drives: 2014 BRZ Limited
I can't remember where, but I read somewhere that you can rig up a 9v battery through the cigarette lighter socket to give a car with push-button start enough power to turn on the ignition so that the car can be roll-started. I don't know if that would actually work with our cars, but it's an interesting idea.
Old 10-28-2014, 12:52 PM   #6
rxlynn
rxlynn's Avatar
Drives: 2015 BRZ Limited 6MT
Owners manual claims this car can't be started by push starting, but gives no other details (p. 398).
rxlynn is offline   Reply With Quote
Old 10-28-2014, 12:54 PM   #7
rxlynn
rxlynn's Avatar
Sorry - just realized this may be a confusing post. I read the manual to mean roll starting the vehicle.
Old 10-28-2014, 01:15 PM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
Can someone test it out and let us know? It might be necessary in an emergency situation.
tobin is offline   Reply With Quote
Old 10-28-2014, 01:22 PM   #9
carma143
carma143's Avatar
Wow. I'm surprised the BRZ Limited supposedly can't be started with a dead battery when rolling. Is this true with all the BRZ and FRS versions? Maybe this is due to the fact that the computer is in control of nearly everything?
Old 10-28-2014, 01:45 PM   #10
sato
sato's Avatar
Drives: Dodge Patitas
How about preventing the steering wheel from locking? Should that be an issue?
Old 10-28-2014, 02:30 PM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The cricket regulator takes up a whole lot of power to push enough pressure through the fuel rails.
Shoving a car with no gas in the cylinders won't get much farther than you can throw it, I recon.
I've got jumper cables in my "What If" box.
JohnJuan (11-07-2014)
Old 10-30-2014, 04:32 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
AAA or Subaru added security! OK I will see myself out...
Old 10-31-2014, 09:57 AM   #13
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
This is why my next car will have a physical key.
This is just one more reason to hate push-button starters.
daiheadjai is offline   Reply With Quote
Old 10-31-2014, 10:38 AM   #14
cliff p.
Drives: '15 BRZ series.Blue
Subaru Roadside service (that 1-800 number) on your window. It comes free with every Subaru purchase
Dead battery? Out of fuel? Blew a tire? Give them a call.
cliff p. is offline   Reply With Quote
The Following User Says Thank You to cliff p. For This Useful Post:
chaoskaze (10-31-2014)
dead battery, push, start
Push start cdrazic93 Cosmetic Modification (Interior/Exterior/Lighting) 6 08-18-2014 09:34 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
push to start pa2gamer02 BRZ First-Gen (2012+) — General Topics 6 03-17-2012 01:01 PM
