| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ WRB Limited MT
Service needed after the second day
The second day of ownership and the truck will not open (MT limited).
It will not open either from outside or inside. Time to take it in ![]() BTW, The key Fob must be the cheapest part of this car. They did not spend any money on it. I hope they change it in the coming years. |
Did you try the key in the trunk keyhole? Inside the trunk there is a trunk reactivation button which would require manually using the key. The idea is luggage security. It might have been accidentally locked. I plan on using it to put my gun or valuables in there.
Track Junkie
Drives: 2004 Honda S2000
Are you sure you did not diable the trunk lid opener. There is a button in the trunk. Try opening the trunk with the key and checking it.
EDIT: Too slow!! Pg 46 of the owners manual for reference. |
Thank you so much for the help. It was exactly what you said. I opened the trunk with the key fob and then activated the button on the left side of the trunk. On the bright side now we know that this feature really works.
Thanks again. |
here is the button
Cool, its a nice option to have. Especially with car prowlers that bust your side window and pop the trunk release button. Otherwise some people just deactivate their trunks by cutting the wire that connects to the lock and unlock.
Drives: BRZ(sold), STI
Haha, yes. I think this should be a sticky. I did it on the first day when I was trying out different features. Pressed the button in the trunk and forgot about it. Had to go read the manual too when I discovered that I can't open the trunk. If you think about it - it makes complete sense: you're supposed to give the electronic key to the valets, keeping the mechanical key. Hence, nothing will open the trunk, except for the mech. key.
First 86
Drives: Whiteout MT FR-S
I did the same thing the second day I had my car!
Don't shop, adopt!
Drives: Moped
Many people are going to run into this issue. Good choice for a sticky...
#10 | |
Drives: Supercharged Golf Cart
#11 |
Drives: BRZ and NA
The NC Miata has the same feature. Based on the miata.net forum, we can expect dozens of post like this in the coming months and years. I thread like this needs to be stickied.
#12 |
Seρor Member
Drives: 2013 SSM DZE BRZ
Or better yet if we just had a "common problems" thread in a simple Q and A format that would be even better. The answers could be set-up to link to individual threads like this one in addition to having a short explanation of the solution to the problem at hand.
#13 |
Night Owl
#14 |
| Needed: Asphalt FR-S photos | Sport-Tech | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 51 | 08-30-2012 08:35 PM |
| Possible BRZs availabe, no pre-order needed | jflBRZ | New England | 22 | 06-15-2012 10:08 AM |
| A Public Service Announcement. | Guff | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 04-21-2012 02:26 AM |
| All it needed was some JB Weld... | 82mm 4g63 | Other Vehicles & General Automotive Discussions | 2 | 09-15-2011 08:12 PM |
