Old 06-03-2012, 03:48 PM   #1
Carlsbad
Drives: 2013 Subaru BRZ WRB Limited MT
Service needed after the second day
The second day of ownership and the truck will not open (MT limited).
It will not open either from outside or inside. Time to take it in
BTW, The key Fob must be the cheapest part of this car. They did not spend any money on it. I hope they change it in the coming years.
Carlsbad is offline   Reply With Quote
Old 06-03-2012, 03:54 PM   #2
BRZranger
Did you try the key in the trunk keyhole? Inside the trunk there is a trunk reactivation button which would require manually using the key. The idea is luggage security. It might have been accidentally locked. I plan on using it to put my gun or valuables in there.
BRZranger is offline   Reply With Quote
Old 06-03-2012, 03:58 PM   #3
Scotty2H
Track Junkie
Scotty2H's Avatar
Drives: 2004 Honda S2000
Are you sure you did not diable the trunk lid opener. There is a button in the trunk. Try opening the trunk with the key and checking it.
EDIT: Too slow!! Pg 46 of the owners manual for reference.
Scotty2H is offline   Reply With Quote
Old 06-03-2012, 04:08 PM   #4
Carlsbad
Thank you so much for the help. It was exactly what you said. I opened the trunk with the key fob and then activated the button on the left side of the trunk. On the bright side now we know that this feature really works.
Thanks again.
Old 06-03-2012, 04:11 PM   #5
Carlsbad
here is the button
Old 06-03-2012, 04:17 PM   #6
BRZranger
Cool, its a nice option to have. Especially with car prowlers that bust your side window and pop the trunk release button. Otherwise some people just deactivate their trunks by cutting the wire that connects to the lock and unlock.
Old 06-03-2012, 04:33 PM   #7
dsgerbc
Drives: BRZ(sold), STI
Haha, yes. I think this should be a sticky. I did it on the first day when I was trying out different features. Pressed the button in the trunk and forgot about it. Had to go read the manual too when I discovered that I can't open the trunk. If you think about it - it makes complete sense: you're supposed to give the electronic key to the valets, keeping the mechanical key. Hence, nothing will open the trunk, except for the mech. key.
Old 06-03-2012, 04:36 PM   #8
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
I did the same thing the second day I had my car!
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 06-03-2012, 04:39 PM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
Many people are going to run into this issue. Good choice for a sticky...
Old 06-03-2012, 10:40 PM   #10
fistpoint
Drives: Supercharged Golf Cart
Can't you just fold the rear seat down from inside?
fistpoint is offline   Reply With Quote
Old 06-03-2012, 10:42 PM   #11
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
The NC Miata has the same feature. Based on the miata.net forum, we can expect dozens of post like this in the coming months and years. I thread like this needs to be stickied.
Grimlock is offline   Reply With Quote
Old 06-03-2012, 10:45 PM   #12
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Or better yet if we just had a "common problems" thread in a simple Q and A format that would be even better. The answers could be set-up to link to individual threads like this one in addition to having a short explanation of the solution to the problem at hand.
Subie is offline   Reply With Quote
Old 06-03-2012, 10:48 PM   #13
MannyO
Night Owl
MannyO's Avatar
I thought of that while reading the posts above. Seems like there's nothing preventing that from happening.
MannyO is offline   Reply With Quote
Old 06-03-2012, 10:52 PM   #14
dsgerbc
Except for the procedure to fold down the rear seats. You can't do it from the inside - gotta pull the straps inside the trunk.
Needed: Asphalt FR-S photos Sport-Tech FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 51 08-30-2012 08:35 PM
Possible BRZs availabe, no pre-order needed jflBRZ New England 22 06-15-2012 10:08 AM
A Public Service Announcement. Guff Off-Topic Lounge [WARNING: NO POLITICS] 16 04-21-2012 02:26 AM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 08:12 PM
