Old 10-24-2014, 09:23 AM   #1
Composite
Drives: 2013 Subaru BRZ
inlet hose void warranty?
So i just installed a perrin inlet hose i received from a fellow forum member and i am curious as to wether it would void my warranty with subaru if i was to bring my car in for repair or oil change. Is this something i can leave on my vehicle when i bring the car in for service? or would i have to remove the part prior to bringing in the car? I have read two different things when searching the forums so i am a bit confused at this point. Also the the inlet tube get so close to touching one of the belts or pullies, has anyone else noticed this?
Thank you to all in advance
Composite is offline   Reply With Quote
Old 10-24-2014, 09:36 AM   #2
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Magnuson-Moss Warranty Act
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
...so your experience may very. My personal advice is to install a turbo, void your warranty proudly and be done with it.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following 5 Users Say Thank You to @Art_Mighty For This Useful Post:
cdrazic93 (10-24-2014), Cop (10-24-2014), gramicci101 (10-24-2014), raven1231 (10-24-2014), zc06_kisstherain (10-24-2014)
Old 10-24-2014, 11:56 AM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
so many threads about this.
1. remove and reinstall OEM
Pro: comfortable going in dealer
Con: time waste removing/reinstall
2. Leave mod in
Pro: don't have waste time on removing/reinstall
Con: Dealer might bitching and you may lose warranty blah blah blah and other hassle
common sense.
Old 10-24-2014, 11:59 AM   #4
Mike&Ike
Drives: Brz
Call your dealership and talk to the service manager. Every dealership will be different so some might be mod friendly while others are not. Ask them you are thinking about doing some modifications and what they think about it.
Mike&Ike is offline   Reply With Quote
Old 10-24-2014, 12:04 PM   #5
phrosty
FWIW when I bought my car in for the B01 ECU update, they could not replicate the idle dip issue and noted I had an intake that might be causing it. I showed them the TSB and they said they hadn't seen it, flashed me right away.
I have never seen them note its presence during any other time I've been there (scheduled maintenance, warranty work for tail light condensation)
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 10-24-2014, 12:17 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Lmao
*service manager see cai*
Voids warranty for tail lights
Old 10-24-2014, 02:00 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I second the turbo option.
The Following User Says Thank You to cdrazic93 For This Useful Post:
@Art_Mighty (11-01-2014)
Old 10-24-2014, 02:04 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Can we get that magnuson moss act stickied on this board?
Old 10-24-2014, 05:34 PM   #9
Composite
Im sad : ( i dont want ti be changing parts out everytime i do an oil change. I live in a townhome and i can change my oil on my own here.
Old 10-24-2014, 05:50 PM   #10
wparsons
wparsons's Avatar
1) They can't void warranty, they can only deny claims.
2) To deny the claim, they have to be able to prove the modification(s) is the cause of the issue and not a legit warranty issue.
So if you have an inlet pipe and have issues with your clutch, transmission, etc you're fine. If you have a vacuum leak caused by the inlet pipe (or installation), you're on your own.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Gunman (10-24-2014)
Old 10-24-2014, 06:05 PM   #11
steve99
If you change any component or work on the car yourself or get someone else even a qualified/certified person to work on your car their is always a possibility of issues with warantee if something goes wrong.
The dealer or Toyota/subaru will always try and blame the aftermarket part or the work done by someone else other than a dealer for the problem.
All the magnussun moss act thingo says is they need to have justification for doing so. Just remember they have trained certified technicians , engineers , lawyers and a ship load of money and time to stuff you around, while you try and fight it.
If your car has no engine related issues leave the inlet hose in, if its got any kind of engine issue idle dip rattle oil use ect swap it back to stock else may be in for a fight as they will try to aportion blame to the aftermarket bit.
inlet is causing idle problems due upsetting MAF readings
it did not seal properly and let dust in damaging engine.
some other component near inlet was damaged/dislodged during installation of inlet causing issue ect
Old 10-24-2014, 06:42 PM   #12
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Yes, your screwed.....did you know driving your car modifies the tires by removing rubber......this voids your warranty.
Gas in the tank not from the factory....yep warranty voided
starting the engine, bearings loose material from friction......warranty voided
did you sit on the seat, the foam was crushed a little an obvious modification.....no more warranty.
Did you wax the paint........that is a modification too......no more warranty for you.
Did you actually use the on the forum.......now your forum warranty is void, this could also mean your forum privileges could be revoked..............
Am I being sarcastic.......you decide, By the way........that voids your warranty too
IceFyre13th is offline   Reply With Quote
Old 10-26-2014, 02:12 AM   #13
Composite
: ) now im even more confused than when i started Ice
Perrin Inlet Hose Cjymiller Want-To-Buy Requests 0 06-24-2014 01:33 PM
Any downside for using Inlet Hose? dejxx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 05-17-2014 03:12 PM
Will this void warranty? Ymerej Issues | Warranty | Recalls / TSB 16 02-13-2014 02:01 AM
WTB: Perrin inlet hose Jaylyons1 Engine, Exhaust, Bolt-Ons 1 10-25-2013 09:44 PM
Will This Mod Void My Warranty? Apex Chase Engine, Exhaust, Transmission 7 07-17-2012 12:38 PM
