Old 10-23-2014, 04:38 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Noise - popping/clack :( Annoying
Description of the noise:
It sounds like a bottle being popped or, its not a loud sound. Its monotone.
With the rear seats down, its louder…
When someone is sitting at the back and the passenger side read, they push their back towards the seat it make a popping noise and the popping noise is still there
The sound feels like its coming from everywhere, but I bet its something from the back.
I reviewed this thread and I don’t know if it is the similar problem or not. If it is, should I go to a Toyota dealer and ask them if the can grease the metal part welded on the chasis?? Or what?
Mikeez is offline   Reply With Quote
Old 10-23-2014, 04:40 PM   #2
aagun
Drives: 86
Common issue use search bottom
aagun is offline   Reply With Quote
Old 10-23-2014, 04:59 PM   #3
Mikeez
Engineering Student
I did use the search, I found a lot but I didn't get it fixed
Old 10-24-2014, 01:55 AM   #4
extrashaky
Drives: 2014 BRZ Limited
Does that mean you'll pull the results out of your ass?
What you're describing sounds like rear deck/trunk popping. If that's it, what's happening is that body pieces are shifting/flexing against each other near the welds and sticking, then popping loose. You can get it fixed under warranty if you take it back to your dealer, but there's also a DIY posted on this site that will work as well as what the dealer will do.
Here's a thread about the problem:
http://www.ft86club.com/forums/showthread.php?t=13451
Here's the DIY to fix it:
http://www.ft86club.com/forums/showthread.php?t=44636
Read through those and see if that looks like your problem. If that's not it, keep looking.
And a tip on searching this site: Ditch the built-in search, because it sucks. Instead, use Google and restrict the search to this site using the "site:" tag with this site's domain name. For example, this search:
site:ft86club.com deck popping
Gives you this:
You can use that trick on any site by just inserting the appropriate domain name after the "site:" tag.
Old 10-24-2014, 02:30 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 10-24-2014, 07:36 AM   #6
ZZT86
ZZT86's Avatar
Drives: BR86
It's not exhaust when cold @ start up is it ?
ZZT86 is offline   Reply With Quote
Old 10-24-2014, 01:28 PM   #7
Mikeez
Engineering Student
Does that mean you'll pull the results out of your ***?
Gives you this:
I read through this, but thanks so much buddy. Appreciate the useful comment and help
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
TRD Air Intake Popping Noise ButtonMasher Issues | Warranty | Recalls / TSB 2 03-27-2014 02:18 PM
foot rest popping noise abutterman Issues | Warranty | Recalls / TSB 34 02-20-2014 11:56 PM
Very annoying rattle/noise in the back of my BRZ. Any help? MrGamer BRZ First-Gen (2012+) — General Topics 6 08-02-2013 09:32 AM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
