Old 03-24-2014, 12:01 AM   #1
ButtonMasher
ButtonMasher's Avatar
Drives: 2013 Ultramarine Scion FR-S
TRD Air Intake Popping Noise
So I intalled the TRD air intake at home a couple days ago to save some money. Last night I started it up and there were two hollow popping noises. You can't hear it from inside the car I had a buddy on the outside. It sounds like the same sound that you would get if you hit your palm on one end of a tube. All my connections seem tight. Any idea what this is?
ButtonMasher is offline   Reply With Quote
Old 03-24-2014, 06:21 AM   #2
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Did it make this noise before the TRD install and other than this does it run fine? I find these motors sometimes make a couple of odd noises upon cold startup but don't think it's anything to worry about. I also installed my TRD intake and doubt you did anything wrong - if I can do it it's not rocket science. I assume you did disconnect the battery and reconnect upon install (ECU needs to re-set and adjust to the new intake). Installing the relocated MAF is easy but it took me a few minutes to figure out how to properly secure the wiring to it.
I love my TRD intake, smoother idle and more responsive. Also got rid of that stupid sound tube and cleaned up the engine bay.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 03-27-2014, 02:18 PM   #3
ButtonMasher
It didn't make this noise before but other than that it runs completely fine. Yeah I disconnected the battery and installed the MAF correctly. Thanks for your input!
Sent from my Nexus 4 using Tapatalk
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Popping noise from engine bay during start up, free rev, light roll on throttle heeltoe86 Tracking / Autocross / HPDE / Drifting 44 12-01-2014 09:28 PM
foot rest popping noise abutterman Issues | Warranty | Recalls / TSB 34 02-20-2014 11:56 PM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-27-2013 11:56 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
