Old 10-22-2014, 09:35 PM   #1
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
Cel is on, but no code on my OFT device
came back from work, car has around 44 000 km. just after a stop at the gaz station, the Cel light went on like a km of driving. arrived at home 5 km later, stopped the car, no symptom of anything, first time i can recall this has happened.
took my OFT, plugged in, tried to see a error code, the tablet say's everything is fine, no error code.. but the Cel is still on!
what can it be? any clue?
Walla Walla is offline   Reply With Quote
Old 10-22-2014, 09:39 PM   #2
raven1231
oh man....Is you car still under warranty?
Old 10-22-2014, 10:35 PM   #3
Walla Walla
Hicas Thread Basher
yes and no
should be, but with oft, header without cat and crawford powerblock, it's more than obvious that the dealer could say that i've ruined it!
went outside 2 min ago, no code again, and the cel is gone....! i checked my gas cap, and i could lock it 1 click more... so maybe it was the problem... I hope!
Old 10-22-2014, 11:54 PM   #4
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Your cel could be popping up from the tranny ecu...OFT will not show those codes.
Triumphrider is offline   Reply With Quote
Old 10-23-2014, 12:19 AM   #5
foompla
Drives: hot lava frs
Aftermarket scanner will show any P**** codes. Including transmission.
foompla is offline   Reply With Quote
Old 10-23-2014, 12:53 AM   #6
steve99
as per other posts oft only reads engine ECU codes, code may be from other control units in car ie trans , body control traction control ect.
if it came on after fill up check gas cap is tight else it will throw an evap system cel code. OFT will clear codes though inless it a permanent fault
buy cheap obd scanner or get auto shop to read code for you
Old 10-23-2014, 08:08 AM   #7
stevemp5
Drives: scion fr-s
I BET on the fuel cap!
stevemp5 is offline   Reply With Quote
Camber Measurement Device PPX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-29-2014 02:41 PM
Oft won't connect device to laptop b1gb2olo Software Tuning 3 09-28-2014 05:56 AM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
HKS Flash Device xwd Software Tuning 1 11-23-2013 09:29 PM
hans device 7thgear Other Vehicles & General Automotive Discussions 8 01-30-2012 12:33 PM
