Old 10-22-2014, 12:05 AM   #1
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Pull header for oil pan replacement?
They stripped the threads on my oil pan at the last oil change yesterday. The communications were bad, so now I know today, and now I'm leaking oil all over the place. Will they need to pull the header for an oil pan replacement? It's a Borla EL.
Last time, they stripped a lug nut. They said it had been overtightened before they got to it, but I doubt that. Probably just a bit of righty tighty when they applied the air gun. Oops! I actually bought a bunch of studs just in case. I guess i should get an oil pan just in case.
I'll see how big the puddle is tomorrow morning. Might head straight in and demand a loaner. I don't want to wait and then destroy my engine.
Old 10-22-2014, 12:08 AM   #2
gramicci101
Off Topic
Why do you take your car there again? I don't think "free" maintenance is worth anything when the people doing the maintenance didn't graduate elementary school.
Old 10-22-2014, 12:26 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
I went there after the dealer I bought it from took 4 tries to get the USB working. Third closest dealer is about 30 minutes away. Sigh. And I was about to buy a Tundra. Meanwhile the Dodge and Chevy dealers don't know shit about their products and the Ford dealer is high pressure. At least the BMW dealer gave nice loaners, but I needed them too many times. Like 10.
Old 10-22-2014, 01:17 AM   #4
civdaddy
Drives: Slow
Man that's just terrible service. 30 min away. They should be sending a flat bed to bring your car to them.
civdaddy is offline   Reply With Quote
Old 10-22-2014, 09:22 AM   #5
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
damn, now to have to be worried about them putting transmission fluid in your engine instead of oil
good luck with it man, id deff call them and make them send a flat bed to your location!
Old 10-22-2014, 09:50 AM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Could also just re-tap/thread the oil pan. maybe heli-coil
Old 10-22-2014, 10:01 AM   #7
Or is it even stripped?
Did they just try to use the same crush washer and it is leaking around that?
Old 10-22-2014, 10:36 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
Less dealer interaction = better.
They can train 16 year olds to do basic work, why can't the owner do it?
The only work I would take to dealer is warranty. And even then I worry...
Old 10-22-2014, 05:03 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
My loaner rental is a Ram 1500 with the Hemi. LOL! I was thinking of buying one, so I guess I get an extended test drive. Doesn't do welll in the corners though.
Old 10-22-2014, 05:04 PM   #10
gramicci101
Off Topic
Of course it doesn't. With the Hemi you're supposed to gas it in the corners to swing the rear end around.
Old 10-22-2014, 05:12 PM   #11
Just make sure there isn't an FRS splattered on the back bumper after you do!
Old 10-22-2014, 05:15 PM   #12
tennisfreak
Drives: 2018 BMW M240i
If you are going to try and repair it I recommend Time-Sert.
About 100x better than a heli-coil and stronger than just retapping the hole.
I stripped the oil pan on my Gixxer and did a Time-Sert repair on it. Super easy and strong as hell.
http://www.timesert.com/
Old 10-22-2014, 05:25 PM   #13
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
On a side note I rented a hemi truck and it used like 1 gal / mile. Was terrible on gas. Seriously like 10 mpg maybe.
TStafford is offline   Reply With Quote
Old 10-22-2014, 10:59 PM   #14
EAGLE5
Dismember
EAGLE5's Avatar
On my commute to get the kids and to work, it was about 20mpg. I wasn't planting it constantly. I was impressed, actually. However, the truck drives like a truck, fo sho.
If they Pull The Plug exam2300 Scion FR-S / Toyota 86 GT86 General Forum 18 06-26-2014 11:59 AM
Broke Oxygen Sensor during Header Replacement - Can i run w/o one? Adeel Engine, Exhaust, Transmission 7 05-20-2014 02:12 PM
About to pull the trigger on a DA Polisher m.wood0213 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-05-2014 12:53 PM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
How do you pull the front sidemarkers? DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 9 06-20-2012 10:27 AM
