Drives: 2013 FRS
Turbo oil feed
Where else can I get my oil feed supply instead of the hex head cap on the top of the engine block? The current setup I have at the top of the engine is going to be in the way of moving my throttlebody forward.
Drives: 2013 FRS
Looks like fa20 club ties into some sensor on the right side front of the head? T'd into oil pressure sensor or something?
Drives: Sterling BRZ Ltd
You can tee into the factory oil pressure sensor, its located below the oil filter in the front cover. Its the one with a single wire connection.
Drives: 2013 FRS
Thanks! Is it cool to have the extra weight of a T hanging off there without any sort of bracket holding it up?
you can remove the factory idiot light if you have another oil gauge installed.
Drives: 2013 FRS
Only have the OE one unfortunately. I'll try the T and keep an eye on it.
Remember me?
Drives: BRZ Series.Blue
I used the oil galley plug.
http://www.ft86club.com/forums/showthread.php?p=690595 Last edited by glorydays; 10-21-2014 at 08:13 PM. |
#8 | |
Boosted Member
As above, Teeing off from the oil pressure sensor works fine. I've had mine like that for almost a year without issue.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
There's also a spot under the passenger side fuel injector cover. That's where my oil pickup is
#10 |
Drives: FR-S 10 #103 AT
Just out of curiousity (it is related), where does it return?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#11 | |
Most returns will be back into your oil pan. I have the avo setup and it returns via a pump into the rh side rear cam plate
#12 |
So to go turbo you have to mod your oil pan?
#13 |
In most cases, yes. A lot of kits come with pretapped oil pans or give the option to buy one
#14 |
Remember me?
Gravity return to cam plate.
| Scion FRS and Subaru BRZ FENDER FLARESin the design stages. Need Feed back | eight08customs | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 03-16-2014 08:46 AM |
| FIVE AD by FIVE AXIS - WHEELS!! I need some feed back!! | jshum | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-27-2013 05:23 PM |
| Dry turbo oil feed | Silverdub | Forced Induction | 27 | 04-03-2013 08:40 PM |
| Tapping my oil feed | Silverdub | Forced Induction | 9 | 10-17-2012 04:22 PM |
| Ebisu Live Feed | TylerLieberman | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 08-18-2012 10:44 AM |
