Old 10-21-2014, 06:17 PM   #1
mhiscott
Drives: 2013 FRS
Turbo oil feed
Where else can I get my oil feed supply instead of the hex head cap on the top of the engine block? The current setup I have at the top of the engine is going to be in the way of moving my throttlebody forward.
mhiscott is offline   Reply With Quote
Old 10-21-2014, 06:21 PM   #2
mhiscott
Drives: 2013 FRS
Looks like fa20 club ties into some sensor on the right side front of the head? T'd into oil pressure sensor or something?
Old 10-21-2014, 07:05 PM   #3
mrk1
Drives: Sterling BRZ Ltd
You can tee into the factory oil pressure sensor, its located below the oil filter in the front cover. Its the one with a single wire connection.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-21-2014, 07:10 PM   #4
mhiscott
Drives: 2013 FRS
Thanks! Is it cool to have the extra weight of a T hanging off there without any sort of bracket holding it up?
Old 10-21-2014, 07:29 PM   #5
mrk1
you can remove the factory idiot light if you have another oil gauge installed.
The Build Thread
Old 10-21-2014, 07:43 PM   #6
mhiscott
Drives: 2013 FRS
Only have the OE one unfortunately. I'll try the T and keep an eye on it.
Old 10-21-2014, 07:44 PM   #7
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
I used the oil galley plug.
http://www.ft86club.com/forums/showthread.php?p=690595
glorydays is offline   Reply With Quote
Old 10-21-2014, 08:05 PM   #8
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Originally Posted by glorydays View Post
As above, Teeing off from the oil pressure sensor works fine. I've had mine like that for almost a year without issue.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-21-2014, 08:49 PM   #9
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
There's also a spot under the passenger side fuel injector cover. That's where my oil pickup is
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 10-23-2014, 06:20 PM   #10
mid_life_crisis
Drives: FR-S 10 #103 AT
Just out of curiousity (it is related), where does it return?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-23-2014, 07:21 PM   #11
protpibe
protpibe's Avatar
Most returns will be back into your oil pan. I have the avo setup and it returns via a pump into the rh side rear cam plate
Old 10-23-2014, 09:17 PM   #12
mid_life_crisis
So to go turbo you have to mod your oil pan?
Old 10-23-2014, 09:23 PM   #13
protpibe
protpibe's Avatar
In most cases, yes. A lot of kits come with pretapped oil pans or give the option to buy one
Old 10-28-2014, 05:51 PM   #14
glorydays
Remember me?
glorydays's Avatar
Gravity return to cam plate.
Scion FRS and Subaru BRZ FENDER FLARESin the design stages. Need Feed back eight08customs Cosmetic Modification (Interior/Exterior/Lighting) 27 03-16-2014 08:46 AM
FIVE AD by FIVE AXIS - WHEELS!! I need some feed back!! jshum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-27-2013 05:23 PM
Dry turbo oil feed Silverdub Forced Induction 27 04-03-2013 08:40 PM
Tapping my oil feed Silverdub Forced Induction 9 10-17-2012 04:22 PM
Ebisu Live Feed TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 0 08-18-2012 10:44 AM
