Lacking brains
Drives: frz
Car idles great, dies on throttle.
Cross posting this from the fi section to get some more direction to go in.
Car has kw sc, vta catch can, stock on engine otherwise. So far i've checked all sc kit plumbing, all vaccum lines (including spraying with cleaner), put a boroscope on the throttle body and sc turbine, changed the plugs, picked up a spare coil pack, removed the sc from the picture (reroute plumbing directly, stock map sensor, stock tune), put the sc back into the loop as it was. Vehicle cuts power and evetually dies under throttle application, currently around 2.5k rpm. Especially now with new plugs the idle is smooth, video was pre plug change. No cel. http://www.datazap.me/u/utekineir/ne...0&data=5-41-66 [ame="https://www.youtube.com/watch?v=m-P_7FVZ71g&list=UUhvDJ0loszAdzRWUwe6V3-A"]External - YouTube[/ame] passenger side image by utekineir, on FlickrDriver side image by utekineir, on FlickrRight now i'm leaning toward a fueling issue. Unfortunately i'm log retarded when it comes to reading them. Thanks,
Drives: Subaru BRZ 6MT WRB
Did the car started to do that all of a sudden? Any check engine codes?
Maybe fuel pressure. To test if it's fuel pressure related, apply throttle and spray in some carb cleaner in the intake. It may backfire from the throttle body, so take care. If you can run the engine with the carb cleaner, the fuel pressure is too low. I would guess that the timing chain is off, the ecu would trigger the spark way off the normal timing when throttle is applied. |
#3 | |
Lacking brains
Drives: frz
New video, same symptoms. [ame="https://www.youtube.com/watch?v=m-j7mBo26JM"]Power cut - YouTube[/ame] |
#4 | |
Lacking brains
Drives: frz
Lacking brains
Drives: frz
What is it?
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| Car dies after 15-20 minutes? | PolishFrs13 | Issues | Warranty | Recalls / TSB | 28 | 10-08-2015 04:28 PM |
| Used car from dealership randomly dies, what to do? | mike the snake | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 08-20-2014 07:41 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
