Old 10-15-2014, 10:45 PM   #1
Idriveft86
Idriveft86's Avatar
Drives: 2014 Scion FR-S
Help! Running water.
Has anyone noticed water (I mean lots of water) dripping from the glove compartment area?. I first turned the fan speed to 1, temp to cool-cold, a minute or two later it started making this sound running water like sound, then a hissing sound followed by a loud hissing sound and BOOM her water broke? ... Seriously I'm thinking its the AC but there was so much water.
Idriveft86 is offline   Reply With Quote
Old 10-15-2014, 10:57 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Drip tube plugged? Dunno about the hissing sound.
Old 10-15-2014, 11:47 PM   #3
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
possible heater core if there is alot of water inside the car
ExxelDistributions is offline   Reply With Quote
Old 10-15-2014, 11:55 PM   #4
HapaHaole
Drives: Grocery cart
There would be an obvious smell if it was the heater core.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 10-16-2014, 09:59 AM   #5
Idriveft86
Idriveft86's Avatar
Ok, they say it's the mesh of an evap system that got clogged by spider web and they're charging me $150 to service it LOL
Old 10-16-2014, 11:53 AM   #6
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Sounds like your A/C drain hose. It is generally about $50 to remove and clean it at my dealership. $150 is robbery.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 10-16-2014, 12:00 PM   #7
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
That's all robbery.
Use a metal clothes hanger or something, get under the car and shove that shit up in the drain hose.
Paying someone $50 to clean out a hose is blasphemy. $150 is insanity.
Kotu100 is offline   Reply With Quote
The Following User Says Thank You to Kotu100 For This Useful Post:
continuecrushing (10-16-2014)
Old 10-16-2014, 12:13 PM   #8
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
A/C condensate drain is plugged. 5 minutes to clear with a coat hanger.
billwot is offline   Reply With Quote
Old 10-16-2014, 12:28 PM   #9
Idriveft86
Idriveft86's Avatar
To late, but thank you. at-least I know what to do next time. I got a little panicky when this thing started gushing water to the carpet LOL My worries was water damaged and the electronics if I wait longer. After taking some of the water out next is to buy some moisture absorbents to finish it off. Can someone move this thread to the issues section?.
Old 10-16-2014, 02:16 PM   #10
tomkozski
Drives: 2017 WRB BRZ w/ PP
Wait, your dealership is making people pay? This sounds like a warranty issue - it's a design flaw, given how many of these threads are popping up (I have the same problem, noticed it last weekend). No way should I be paying to unclog a drain after only 1 year of ownership.
tomkozski is offline   Reply With Quote
Old 10-16-2014, 02:18 PM   #11
They should have designed for spiders?????
Old 10-16-2014, 02:21 PM   #12
Silver Ignition
APEXHNTR
It's not considered by ANY manufacturer (I've worked for Honda and a few other Toyota dealerships) to be a "defect in worksmanship or parts" so it is therefore not covered under any type of warranty.
It is generally caused by insect webs/nests in the hose and therefore an "act of god"
Just to be clear this isn't what I believe but it's the automaker's official stance. I will usually do the first one for free and warn the customer of the potential for it to happen again. Toyota has parts kits for some cars which include an insecticide tip for the hose to keep your unwanted passengers out, but as far as I know there isn't one available for the 86 as of yet...
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
Tcoat (10-16-2014)
Old 10-16-2014, 02:23 PM   #13
tomkozski
Of course. Mazda had a whole recall because spiders were clogging up the fuel system. I think GM had a similar recall too. If this was rare, I can see dealerships charging. But given how 'young' this car still is, it's obviously a design flaw if there are multiple threads about this issue.
Old 10-16-2014, 02:26 PM   #14
Silver Ignition
APEXHNTR
It's not just the 86. It's almost every car. I've seen it on almost every model of every car company I've worked for.
#1867 of 2500
Water temp. Reaper Engine, Exhaust, Transmission 7 08-28-2014 10:20 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 07:57 AM
