Old 10-14-2014, 02:14 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OFT: New firmware and new user software
Just so no one gets surprised, we reeled a new firmware version last night (firmware #130). There is also an updated OpenFlash Manager (1.12.0). As always, the firmware will auto-update through OpenFlash Manager. And OpenFlash Manager should auto-update itself as well unless you are running on a Mac through Parallels. In that case, you will have to set OpenFlash Manager to Administrative privileges through Windows. Of if all else fails, you can just download the new installer which is available in the downloads section of our website. Just run the executable and it should over-write the old version of OF Manager with the new one.
Changes to OFT:
1) Flashing Save Button when data logging. Simple but serves as a good indication that the data logging function is active
2) Higher resolution bar graphs in the Realtime Data Display
3) A minor bug fix in regards to how FLKC, KC and KC learned is displayed in the Digital LED display screen
Changes to OF Manager:
1) Nothing that you will be aware of at this time
Cheers
Shiv
Old 10-14-2014, 03:45 PM   #2
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Dang I was hoping for the Mac version. Ohwell, glad to see constant improvements and the product moving forward.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 10-14-2014, 04:01 PM   #3
gramicci101
Off Topic
Shiv, for those of us that simply flash an OTS map and let it go, is there anything we need to be concerned with? Thanks.
Old 10-14-2014, 04:30 PM   #4
Shiv@Openflash
Drives: 2013 FRS
Nope
These updates are just to the user interface and Datalogging. Basic read/write functionality is the same as it has always been.
Old 10-14-2014, 09:56 PM   #5
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Hey Shiv,
I just updated OF Manager and my OFT and tried to reflash the tune on my car as I'm running a version from April 2014.
It keeps saying "unable to connect to ECU". I also am not able to do the real time data display anymore which also makes sense if it isn't able to pick up the ECU. I also am sure to have my car on "key on" (where the radio,fans,etc work), doors shut etc.
Any idea what is going on?
Brahsbrah is offline   Reply With Quote
Old 10-15-2014, 02:47 AM   #6
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Brahsbrah View Post
Hey Shiv,
There is no reason for the communication error as far as software/firmware updates go. First thing I would do is check the pins on the obd2 connector to make sure they are not bent.
Old 10-15-2014, 03:10 AM   #7
steve99
Hey Shiv,
sounds weird but update the template files as per instructions on openflash downloads site
Old 10-15-2014, 01:47 PM   #8
Brahsbrah
I've had the cable plugged in for a few months now and the end was sitting on the floor wedged between the seat and center console...I'll take a peek later.
Thanks for the quick reply!
Old 10-15-2014, 02:16 PM   #9
Shiv@Openflash
Drives: 2013 FRS
So it was plugged in all this time? If so, try unplugging it and then plugging it in again. That should do the trick.
Old 10-15-2014, 02:45 PM   #10
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
I see an new icon on my OFT now..wink wink
TStafford is offline   Reply With Quote
BRZ HEADUNIT FIRMWARE beagoodruslan Electronics | Audio | NAV | Infotainment 7 07-27-2014 07:31 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
ecutek firmware problem ahk Software Tuning 5 07-29-2013 10:31 AM
Unichip Firmware issue jybrd Software Tuning 11 07-22-2013 02:40 PM
BRZ Nav Unit Firmware michaelahess Electronics | Audio | NAV | Infotainment 5 05-09-2013 08:55 PM
