Old 07-19-2013, 11:12 PM   #1
jybrd
jybrd's Avatar
Drives: 2013 Scion FRS
Unichip Firmware issue
I got the program installed and I continued to update the firmware. It comes up with an error at 74% Now my chip cant communicate with the program Help, what do I do?
jybrd is offline   Reply With Quote
Old 07-19-2013, 11:17 PM   #2
jybrd
jybrd's Avatar
I may have gotten it.
I do have a question for Unichip users.
I get that 87, 89, and 92 is the octane and i am currently going to try one in 89 and one in 92.
My question is when I go into 89 it comes up with list
Fuel In
Fuel Out
Fuel Standard
What is the difference? I can only choose 2 and just want to do it right.
I then have a question when I choose fuel out it has the timing list, again what is the difference here?
Old 07-20-2013, 02:45 AM   #3
bakerr6
Drives: 2013 raven black fr-s
standard is just that, a standard map.
in vs. out means it's either adding more fuel/timing or pulling fuel/timing. I would try them all and see which one feels best to you
bakerr6 is offline   Reply With Quote
Old 07-20-2013, 09:28 AM   #4
wparsons
wparsons's Avatar
IMO, don't mess with fuel/timing unless you have a wideband gauge at the very minimum, ideally a wideband and dyno.
flickr
Old 07-20-2013, 10:06 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
An engine will make the most power while running dangerously lean.
Old 07-20-2013, 10:25 AM   #6
bakerr6
I logged all of the different tunes when running mine and I can tell you the variance between the different tunes was very little. my car was never running lean
Old 07-20-2013, 01:34 PM   #7
jybrd
jybrd's Avatar
Hey guys, ok got it installed and loaded two maps. First was 89, Normal timing, Normal fuel, and did the Airaid intake with exhaust.
Second map was identical except for 92 instead of 89.
I really didnt notice any type of performance upgrade. Did I maybe do the wrong type of map?
Old 07-20-2013, 06:11 PM   #8
wparsons
wparsons's Avatar
1) Playing with tunes without a wideband and dyno is very dangerous
2) It takes about 10hp to be noticeable from behind the wheel, which is a big gain to get from small tweaks.
If you're going to play with this stuff you NEED to get a wideband and tune it on a dyno.
flickr
Old 07-20-2013, 06:48 PM   #9
jybrd
jybrd's Avatar
I dont have a wideband, but it seems that the map that works for me is 92, fuel out, timing out.
Old 07-21-2013, 09:32 AM   #10
wparsons
wparsons's Avatar
Without a wideband and dyno you're really just shooting blind... all that matters is if you're happy with it though.
flickr
Old 07-22-2013, 11:10 AM   #11
Mike86
Drives: Scion frs
Im pretty sure jack from unichip said that all the different combos and map variances were safe!! Must not be a big differnce from standard to fuel out timing in!! Thats what i hnderstood from his posts anyways
Mike86 is offline   Reply With Quote
Old 07-22-2013, 02:40 PM   #12
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Fuel In
Fuel Out
Fuel Standard
I hate to do this to you, but I read everything here http://www.ft86club.com/forums/showt...hlight=unichip
This should help you answer your questions, and also give you more questions to ask............
IceFyre13th is offline   Reply With Quote
Any dealers offering AHA Radio Firmware upgrade? DNAPoPo BRZ First-Gen (2012+) — General Topics 18 07-06-2013 07:11 PM
Looking for a Unichip CSI:86 Engine, Exhaust, Bolt-Ons 2 06-30-2013 04:57 PM
BRZ Nav Unit Firmware michaelahess Electronics | Audio | NAV | Infotainment 5 05-09-2013 08:55 PM
FS: Unichip subiestar Engine, Exhaust, Bolt-Ons 3 04-09-2013 07:00 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
