OFT Issue
Hey guys,
I'm having an issue with my OFT, maybe someone has encountered this before. I went to flash my car to 2.061, I followed the on screen instructions. Once I got to the second "key on and confirm" screen after turning the ignition off, I selected okay but then it the message "key on and confirm" popped up gain. I selected okay again, and still no success, it said there is a writing a error and to try again. I've tried flashing the original file only to reach the same issue of not doing anything past the "key on and confirm" screen. I checked my connections, but it seems to not recognize that the key is on the on position. Any ideas? Thank you, Rod |
Drives: '13 DGM BRZ Limited
Loose OBDII connector maybe?
Sent from my SAMSUNG-SM-N900A using Tapatalk |
It went through the whole writing process. But on the post-writing check, it stopped recognizing the key on the on position. The cable was not touched at all. Thanks for the input.
Still looking for other possible solutions. Last edited by HotRodPA; 10-12-2014 at 02:23 PM. |
#4 | |
does car still run ? make sure you let oft do all its updates connected to computer with internet and also apply the latest template file from the oft downloads page. make sure battery is good all electrical stuff off in car radio a/c lights ect dont open close doors or mess with anything during write reload tune files into oft if its still crook contact the oft guys |
#5 | |
Drives: '13 UM86
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
The OFT was updated as much as possible prior to the flashing attempt. Went and got a new battery in hopes that it was the cause, no luck still. Definitely have the ignition set to "on". I'm not sure what to try next. Contacted Shiv via pm, haven't heard anything yet. If something had occurred during the writing process then I would be able to point at something being the cause, but it was uneventful until it was done writing. I think this is about my 6th time flashing car, and no issues the past. Thanks for your help everyone, keep the ideas flowing.
#7 | |
use email to him or the sales guys at openflash sales@openflashperformance.com does the car start/run ok ? are you running windows 8 if so have you loaded checksum patch ? |
#8 | |
#9 | |
Drives: 2013 FRS
#10 | |
If car wont crank it sounds like write to ecu has gone bad and when it checks the checksum is finding it bad. Did you edit any of your ROM's with romraider, or your just flashing the standard oft rom. Do you get same issue when you flash back your stock rom |
#11 | |
#12 | |
Drives: 2013 FRS
#13 |
Drives: Toyota 86 GTS
If you have push button start, make sure the key is in the car with you
#14 | |
Have you tried writing back stock rom ?? If writing back stock rom gives same result then try removing a battery cable for a minute in case ecu in weird state. then try stock rom again. Make sure your key fob is right near the start button and away from any laptop, also dont have oft connected to car and laptop at same time If all that fails its not looking to good. but maybe shiv has a trick. |
| a little issue here | Asian Delight | Electronics | Audio | NAV | Infotainment | 8 | 02-10-2014 03:32 PM |
| A/C Issue? | FUN BRZ | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 02:34 PM |
| BRZ Nav MP3 issue | TheRipler | Electronics | Audio | NAV | Infotainment | 5 | 09-06-2013 02:21 PM |
| Serious issue with FRS!!!!. | _F-R-S_ | Issues | Warranty | Recalls / TSB | 16 | 08-28-2012 10:08 AM |
| Cel issue | Z06tofrs | Issues | Warranty | Recalls / TSB | 2 | 08-27-2012 10:13 AM |
