Old 02-10-2014, 12:53 PM   #1
Asian Delight
Drives: Scion Fr-s 2013
a little issue here
When I had an Iphone, the usb cable would charge it just fine, but when i got a S4, the battery too forever in a day to charge to 1 percent. So naturally i bought a car charger. This is where the issue lies. I've tried two car chargers, and none of them seem to work at all, but they do work on another car i tried on. This tells me there is something wrong with my outlet, anyone else run into this trouble??
Asian Delight is offline   Reply With Quote
Old 02-10-2014, 01:14 PM   #2
White64Goat
Did you try plugging it into the hidden outlet inside the glovebox? Buy a cheap test light to test your other outlet.
Old 02-10-2014, 01:22 PM   #3
Asian Delight
I havent, but someone told me a fuse might have blown up, so i am going to check right now
Old 02-10-2014, 01:25 PM   #4
Asian Delight
the glove box one does not work as well
Old 02-10-2014, 02:01 PM   #5
sshole
Check your fuse.
sshole is offline   Reply With Quote
Old 02-10-2014, 02:02 PM   #6
Asian Delight
Idk which fuse
Sent from my SPH-L720 using Tapatalk
Old 02-10-2014, 02:45 PM   #7
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
There ought to be a guide printed on the fusebox.
JohnJuan is offline   Reply With Quote
Old 02-10-2014, 03:15 PM   #8
Asian Delight
idk which of the accessories it is ahhaha
Old 02-10-2014, 03:32 PM   #9
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
Check all the accy fuses. Don't just visually inspect them, pull them and check for continuity.
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
A/C Issue? FUN BRZ Issues | Warranty | Recalls / TSB 5 02-08-2014 02:34 PM
BRZ Nav MP3 issue TheRipler Electronics | Audio | NAV | Infotainment 5 09-06-2013 02:21 PM
LED DRL issue CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 4 08-12-2013 05:15 PM
TCS Issue subaruatheart Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-26-2013 01:28 PM
Serious issue with FRS!!!!. _F-R-S_ Issues | Warranty | Recalls / TSB 16 08-28-2012 10:08 AM
