Old 10-09-2014, 05:05 PM   #1
tyrantcf
Drives: '16 WRX, CBR1000RR
Best product for removing water spots from windows?
Unfortunately, my car cannot be garaged on a regular basis and my car is starting to show hard water spots on the glass.
What are people using to remove these? I'm terrified of using anything like this that isnt specifically designed for use on automotive glass.
If already posted please direct me!
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 10-09-2014, 05:10 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Automotive glass is still just glass. the exterior surface is not coated with anything special that you'd need to worry about.
Just use vinegar solution to get rid of the hard water spots, then perhaps an application of rain-x if you are so inclined. if the spots are really baked on, you can always go over it w/ an aggressive polishing compound and a rotary/PC.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 10-09-2014, 05:21 PM   #3
tyrantcf
My concern isnt for the glass, its for the rubber, weather stripping, and plastics that surround it. I will try the water and vinegar solution before I get too carried away.
Old 10-10-2014, 12:31 AM   #4
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Extra fine steel wool. Look, I expect some concern for my suggestion but research it. Youtube has more than one video on how to do it.
Originally Posted by paulca View Post
Has anyone mentioned Hitler yet?
Hot Lava is offline   Reply With Quote
Old 10-10-2014, 01:15 AM   #5
Ec1990
Drives: '14 BRZ
Check out CarPro Spotless.
0000 steel wool is a valid alternative but can lead to scratches when used improperly as it still is a physical abrasive. Glass is numerous times harder than the clear coat on your vehicle.
Ec1990 is offline   Reply With Quote
Old 10-10-2014, 02:05 AM   #6
Poodles
Drives: 2015 Series.Blue
Razor blade.
Old 10-10-2014, 11:22 AM   #7
Guzic
Clean as F86ck
Guzic's Avatar
Drives: 2014 Asphalt FR-S
^ this. Use a razor blade at an angle with some type of lubricant such as detail spray. For trim, you can try the vinegar solution and then protecting it with a trim coating/sealant.
Guzic is offline   Reply With Quote
Old 10-10-2014, 11:23 AM   #8
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Originally Posted by Poodles View Post
Razor blade.
Just cut around them really carefully
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 10-10-2014, 11:52 AM   #9
Stay Fresh Car Care
Stay Fresh Car Care's Avatar
Drives: STI
0000 Steel wool and your favorite final polish will work.
Follow us on Instagram @stay_fresh_car_care
Use the code FT86 at checkout to save 10% off your next order at www.stayfreshcarcare.com
Stay Fresh Car Care is offline   Reply With Quote
Old 10-11-2014, 12:13 PM   #10
FRS_KOTO
Drives: Raven
i used cesium oxide powder. it works great !
FRS_KOTO is offline   Reply With Quote
Old 10-11-2014, 12:38 PM   #11
White64Goat
Griot's Garage sells 2 types of glass polish.
Car cover.
Old 10-13-2014, 03:12 PM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
While you're working on the windows, is there a general consensus on what to coat the weather stripping at the top of the window with to prevent the windows from sticking to it? I'm getting what sounds like a window cracking as they break free from the rubber.
how to remove hard water spots DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 08-10-2014 06:53 PM
Water spots in clear coat? Annahra Cosmetic Modification (Interior/Exterior/Lighting) 6 05-31-2014 01:12 AM
Water Spots norcal_brz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-16-2013 01:06 AM
Water Spots MATTrocity Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 09-02-2012 01:37 AM
Hard water spots Double4Free Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-01-2012 10:14 AM
