Honeydew old ID
Drives: GT86
AC Vent Trim plasti dip
can someone please help me here.. I want to plasti dip this piece..how do you guys take it out???
Used to owned M3 and Lotus, but love my GT86 the most.
Because Racecar
Drives: 2014 Scion FR-S
Squeezing it will allow a bit of room to stick something in to pop it out. You can use a flat-head but be careful in scratching or use a rubber removal tool.
Honeydew old ID
Drives: GT86
clear me here plz, Squeezing the rubber part behind the ring the pry it out???
#4 | |
Because Racecar
It's kinda hard to explain but if you just fiddle around you'll be able to get it. |
Honeydew old ID
Drives: GT86
ok.. gonna try it tonight.. thanks man
Drives: DGMBRZ
Because Racecar
You may want to do the door handle trim as well. That one has a slot at the very bottom for a flat-head. You can tape the tip to avoid damage.
Drives: AE86 & Up-Armored ZC6
Stick a screwdriver in the 1 o clock position. If I remember correctly, there are 3 tabs at the 11, 2, and 6 o clock positions. It doesnt take much to pop it off.
Drives: 2014 Scion FRS
try using a credit card
idk how i did it, but when i used a screw driving to take mine off, its made an indent on the plastic, barely used any force when i did it too |
| The Following User Says Thank You to WhiteFRS69 For This Useful Post: | skyloran (10-07-2014) |
#10 |
Honeydew old ID
Drives: GT86
Yes man..I already did the door handle over the weekend. now try to work on AV vent ones.
| Interior trim trim clips (Dash Trim Panel) | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-11-2022 07:47 AM |
| Aluminum A/C & vent trim | rokius | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-05-2014 03:51 PM |
| FS: Brand New Driver Side Vent w/ Black Bezel Trim | that_guy | Canada Classifieds | 0 | 02-09-2014 06:57 PM |
| WTB: BRZ chrome side vent trim | JoeBoxer | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-19-2013 10:15 PM |
| Silver interior trim removal for plasti-dipping | ph0en1xtk | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-06-2012 09:54 AM |
