Old 10-07-2014, 01:52 PM   #1
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
AC Vent Trim plasti dip
can someone please help me here.. I want to plasti dip this piece..how do you guys take it out???
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 10-07-2014, 02:13 PM   #2
kchar
Because Racecar
kchar's Avatar
Drives: 2014 Scion FR-S
Squeezing it will allow a bit of room to stick something in to pop it out. You can use a flat-head but be careful in scratching or use a rubber removal tool.
kchar is offline   Reply With Quote
Old 10-07-2014, 02:59 PM   #3
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
clear me here plz, Squeezing the rubber part behind the ring the pry it out???
Old 10-07-2014, 04:40 PM   #4
kchar
Because Racecar
kchar's Avatar
Like using the thumb and index finger on opposite sides of the ring (like at the top and at the bottom) squeeze and it should open a small gap.
It's kinda hard to explain but if you just fiddle around you'll be able to get it.
Old 10-07-2014, 04:42 PM   #5
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
ok.. gonna try it tonight.. thanks man
Old 10-07-2014, 04:49 PM   #6
Flow
Drives: DGMBRZ
http://www.ft86club.com/forums/showthread.php?t=59602
Flow is offline   Reply With Quote
Old 10-07-2014, 04:57 PM   #7
kchar
Because Racecar
kchar's Avatar
You may want to do the door handle trim as well. That one has a slot at the very bottom for a flat-head. You can tape the tip to avoid damage.
Old 10-07-2014, 06:18 PM   #8
ziptiedae86
ziptiedae86's Avatar
Drives: AE86 & Up-Armored ZC6
Stick a screwdriver in the 1 o clock position. If I remember correctly, there are 3 tabs at the 11, 2, and 6 o clock positions. It doesnt take much to pop it off.
ziptiedae86 is offline   Reply With Quote
Old 10-07-2014, 06:32 PM   #9
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
try using a credit card
idk how i did it, but when i used a screw driving to take mine off, its made an indent on the plastic,
barely used any force when i did it too
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
skyloran (10-07-2014)
Old 10-07-2014, 07:02 PM   #10
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
Yes man..I already did the door handle over the weekend. now try to work on AV vent ones.
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
Aluminum A/C & vent trim rokius Scion FR-S / Toyota 86 GT86 General Forum 9 05-05-2014 03:51 PM
FS: Brand New Driver Side Vent w/ Black Bezel Trim that_guy Canada Classifieds 0 02-09-2014 06:57 PM
WTB: BRZ chrome side vent trim JoeBoxer Exterior Parts (Aero, Lighting, Etc.) 0 01-19-2013 10:15 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 09:54 AM
