Old 10-06-2014, 12:32 AM   #1
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
License Plate and Side Marker Lights Won't Turn On - Please Help!
I installed new license plate LEDs that I purchased a few days ago from a reputable vendor. I haven't driven my car at night more than once or twice since installing them, but tonight I pulled into the garage and went around the car to admire the new LEDs - to my surprise, the passenger-side one was out.
I had difficulty with that same light while I was installing it - it wouldn't light up until I removed it and put it back in once, so I thought that that might help again. I wasn't thinking straight since I was tired, but I removed the light while the lights were on (I know I've seen this done with the trunk LED replacement, but as I was tired and thought I could fix the problem quickly I didn't think to turn off the lights before I went to pull out the bulb and try putting it back in).
I put it back in, and it didn't work. I turned the lights off and on and it didn't work - I then noticed that now, the other license plate wouldn't work, and my side markers are now out.
I've tried switching back to my old white license plate LEDs that I had before these new ones, and those didn't work. I tried switching back to the stock ones, and that didn't work.
I am extremely distressed right now as I don't know what my options are or what happened - I am now worried that I shorted something somehow, and I do not know what to do to get it fixed, or if I will have to take it to the dealership (in which case I assume I have to replace all of my LEDs with the stock ones - which I dread because I had huge, huge difficulties installing my side markers appropriately, and I know it'll be worse after removing them and deforming the clips).
If anyone could help me with this issue or tell me my best course of action, I would really appreciate it as I am seriously distressed - this is the first significant issue I've experienced with my car.
Ammunition is offline   Reply With Quote
Old 10-06-2014, 12:37 AM   #2
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Have you checked fuses?
Old 10-06-2014, 01:16 AM   #3
Ammunition
Ammunition's Avatar
Yeah - stopped freaking out and got the manual and used the spare fuse to replace the one that did blow upon inspection; I've just never had to do that before, but it was an easy fix and everything is working as it should now!
Old 10-06-2014, 09:53 AM   #4
Will still need to find out what blew the fuse in the first place or it will likely just keep happening.
Old 10-06-2014, 01:52 PM   #5
Ammunition
Ammunition's Avatar
It was a new license plate bulb that I got a few days ago - the one that I mentioned wouldn't fit completely securely, and was out when I went to check on it which prompted the situation.
This was only the second time I had driven with it on. I've had both my previous license plate LEDs that I re-installed and my side marker LEDs for months now without issue.
The vendor I purchased the replacement light from is working to get me a new one.
Side Marker lights won't turn on uEih Cosmetic Modification (Interior/Exterior/Lighting) 13 09-24-2014 05:33 PM
***Vicious LED License Plate/Trunk/Side Marker Bulb Kit FR-S/BRZ/GT86 *** Vicious LED Interior Parts (Incl. Lighting) 10 09-11-2013 08:55 PM
***Concept Three LED's: 6K White LED Kit (Side Marker, License Plate, Trunk Light)*** Vicious LED Exterior Parts - The Rest 23 11-16-2012 09:47 PM
