Drives: Subaru Forester XT
Modified FR-S / BRZ owners are commenting their cars handle significantly better than stock, so has anyone measured this grip improvement in a quantifiable manner?
Ex: some cars, like the Nissan GTR and new Fiat 500 Abarth display G forces during turns and accel / braking. What is the highest turning grip you guys are recording on your modified FT86 cars and with what wheels, tires, suspension mods, and g force measuring device? |
Because compromise ®
Drives: Red Herring
Transient g can be higher than sustained cornering but at the local track there is no steady state cornering. I am a little impressed by my peak (1.5g) but it is somewhat irrelevant in the grand scheme of going fast. One can generate high transients by jerking on the steering wheel but this will probably happen just before you go cross country off track.
Drives: Used to Drive:Grand-Am GS #54 E36M3
This is data from a different car but the principles will hold for a twin. The peak of -1.76g was held for a total of 0.019 seconds. My takeaway is what it's always been: Peak lateral g-force numbers are entertaining. BTW, that car ran a peak of -1.97g in that turn during the same on-track session. Sensor: Crossbow CXL04LP3 4G Accelerometer.
Trace showing spiky lateral g-forces during two seconds in the middle of a turn in a high-downforce, race-tired race car: ![]() And a video showing the data in action: [ame="https://www.youtube.com/watch?v=gO4Up84jqL8"]WGI Video of T1 to Go with Graph Showing Typical Spiky G-Force Trace - YouTube[/ame] Last edited by dradernh; 10-05-2014 at 11:18 PM. |
Drives: 2013 BRZ Limited
I sustained 1.48 g's through a long, 180 degree, lower speed corner at Miller Motorsports Park this weekend.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
Drives: 2013 FR-S Argento
What are you trying to achieve exactly? Comparison of tire compounds? Or comparison of a wider tire to the stock tires? I think it's tough to accurately quantify differences in g-forces generated by switching tires - too many environmental factors at play. First off you'd have to swap the tires and do a test on the same day, same conditions, close to same time of day, same track/test area (preferably smooth), same wheels, same width, same tire pressures, both tires up to operating temps to really make an accurate quantifiable comparison in generated g-forces. Would be an interesting thing to see - but it's just one small metric among a huge number of factors that lead to better lap times (weight, operating temps, sidewall compliance, rim width, responsiveness, breakaway characteristics, etc). Most appraisals of tire performance are from lap times and driver feedback.
Drives: 2012 Toyota 86
my fastest lap has less gs pulled in most corners compare to the times i try to beat that lap lol.
Junior
Drives: a car
@CSG Mike ?
That Guy
Drives: 2013 asphalt FRS MT
yeah, i agree, i was just mostly making the point that measuring g's is not the best way to measure if your driving faster.
| Tags |
| g force, g grip, grip, lateral g, lateral g force |
| FS: 2014 BRZ Sport Tech with suspension/wheel/tire mods | BRZZZZZZZZZZ | Canada Classifieds | 24 | 10-31-2014 08:15 AM |
| Tire suggestion...245/35/18 with good grip and 20k | continuecrushing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-01-2014 07:24 AM |
| STI Pillowball Trailing and Lateral Links For Rear Suspension Do They Clunk? | krayzie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-06-2014 12:47 PM |
| Lower grip then stock tire | 5th 86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-14-2013 11:04 PM |
| Wheel gap - from suspension height or tire diameter? | CaptainSlow | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-27-2013 12:48 PM |
