Old 10-04-2014, 10:29 AM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
SOSOSOS CRANK PULLEY AUTOMATIC HELP
How do I stop the crank shaft from spinning without holding the flywheel ?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 10-04-2014, 10:29 AM   #2
ScionFR-S
ScionFR-S's Avatar
I have an automatic
Old 10-04-2014, 03:19 PM   #3
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
What? I thought you said this was about the crank pulley. Did you just install the crank pulley? Did you botch the install?
Check the Installation Warning. Maybe you made the same mistake?
JohnJuan is offline   Reply With Quote
Old 10-21-2014, 09:25 PM   #4
rcampici
Drives: GTS86
I have an automatic
I used a cargo strap and rubber that I wraped around the pulley and anchored to the alternator, tension the strap so that the rubber provides friction so you can undo the bolt.
Else remove the starter motor and use the ring gear to hold the crank, note the pulley bolt is very tight to remove.
rcampici is offline   Reply With Quote
Old 10-21-2014, 09:42 PM   #5
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Why not do it the safe way and use a.crank pulley tool
http://www.grimmspeed.com/crank-pull...l-tool-subaru/
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Freeman is offline   Reply With Quote
Old 10-21-2014, 10:30 PM   #6
ramiram1984
Drives: 2016 STi DGM
This was a bitch to do. But you can use flywheel catcher thingy tool (or something strong enough and thick enough for the teeth) and do it that way. This will lock the teeth and you'll be able to (using a breaker bar 22mm socket) remove the crank pulley. Of course, loosen the belt tensioner and move Belt away.
I've only done this once and worked.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
What is best crank pulley? Mixlplix Engine, Exhaust, Transmission 49 10-28-2017 05:44 PM
Removing crank pulley on automatic nlowell Engine, Exhaust, Transmission 11 11-11-2016 11:08 AM
Lightweight crank pulley on an AUTOMATIC Gani21 Engine, Exhaust, Transmission 17 09-30-2013 10:27 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
