Old 10-02-2014, 03:03 PM   #1
Whitebrz15
Drives: 2015 Brz Blue series
Help with Manzo V2 fitment!!
I purchased a Manzo v2 cat back exhaust. Upon installing it there is solid contact between the exhaust and the crossmember/frame. I've seen it happen to a couple others on this forum.
My question is how did you guys get it to fit properly? Longer exhaust hangers? Or did you just return it?
Whitebrz15 is offline   Reply With Quote
Old 10-02-2014, 03:48 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
That's what you get for buying cheap poorly engineered ricer parts.
Use a hammer to dent the piping to clear the frame, or bend the exhaust hangers to get more clearance...
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 10-02-2014, 04:40 PM   #3
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Actually nameless over and front pipe has this problem too, so it's not the cheap shit. At least he's not as mad as me paying $400+ for just a front over that his the frame
umpadupa is offline   Reply With Quote
Old 10-02-2014, 04:42 PM   #4
aznatama
aznatama's Avatar
Still poorly engineered. Regardless, just manually make it fit.
'14 BRZ LTD MT DGM
Old 10-02-2014, 04:48 PM   #5
BRZ?
Drives: 2014 SWP 6MT BRZ
HA HA HA
2014 SWP 6MT BRZ Limited
Diode Dynamics Door, Trunk, Dome, Vanity, License Plate and Side Marker LEDs
GrimmSpeed Plate Relocation
BRZ? is offline   Reply With Quote
Old 10-02-2014, 10:09 PM   #6
Whitebrz15
Well thanks for the help guys seems like this forum is just like nasioc instead of helping a fellow subie out just talk shit.
The Following User Says Thank You to Whitebrz15 For This Useful Post:
niceguy21 (10-03-2014)
Old 10-02-2014, 10:10 PM   #7
Whitebrz15
They said they'll take it back but there's so many people with it I figured someone could help me out
Old 10-02-2014, 10:38 PM   #8
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Hey Guys - I have a booger in my nose and want to get it out. It's firmly planted up in there, and blowing doesn't help. Please, don't tell me how to pick my nose... just come do it for me. I don't know what to do.
Help!
sdemo is offline   Reply With Quote
Old 10-02-2014, 10:51 PM   #9
steve99
If you dont have tools/skils to fix it just take it to local exhaust shop, they will sort it in less than 30 minutes for minimal cost, well worth the small outlay, they will likely heat and bend it which is a much better option than belting it with a hammer
Old 10-02-2014, 11:02 PM   #10
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
People on this forum are fucking ridiculous.
Wish I could help.
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
Old 10-02-2014, 11:17 PM   #11
aznatama
aznatama's Avatar
I was serious... Nothing wrong with denting or bending part of it to make it clear the frame. Essentially what exhaust shop will do. It's all a matter of how it's done. Nobody said to take a sledge hammer to it and crush the piping. Use a buffer, like a piece of wood or something to smoothly dent the correct area...
You're dealing with steel, a malleable metal. Malleate it.
'14 BRZ LTD MT DGM
Old 10-02-2014, 11:28 PM   #12
Whitebrz15
Thank you. I will give it a shot this weekend and see if I can get it to fit right.
Old 10-02-2014, 11:33 PM   #13
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
I did some hammer work to the hangers to push the pipes a little further south. I only ever get a rattle at really low rpm's in reverse now. I might get some aftermarket hanger bushings at some point because I hear they are a little longer.
Vampyre is offline   Reply With Quote
Old 10-03-2014, 11:09 AM   #14
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I have the Manzo as well. Bought it used for under 200 from another member. Was told it was only slightly louder than stock and that fiend was spot on but the sub200 price tag told me otherwise.
At the moment mine barely clears underneath the car. I ha to fiddle with the hangers to make it work. Also the order in which you complete the connections effects it as well. I used a thicker gasket too. This might have helped.
Honestly if you paid full asking price, return it. Because once you get it to clear the sub frame, you then have to attempt to get the exhaust tips centered and aligned properly, which is not going to happen on my exhaust unless I cut the piping and re weld it. I plan on buying a Perrin exhaust soon
Manzo v2 can be had for around 380ish. If save up the extra 300 require to get an invidia or a Perrin for sure. Hope I was of some help.
Edit: if you hammer it you probs can't return it. This exhaust also drones pretty heavy at highway speed. Not recommended for a daily driver that involves highway.
GotBRZ1691 is offline   Reply With Quote
WTB Manzo V2 Whitesoul Want-To-Buy Requests 2 08-27-2014 01:14 AM
How to install Manzo 2 exhaust? Timmy_Jones Engine, Exhaust, Transmission 13 08-01-2014 08:13 PM
Manzo V2 Exhaust. Anyone else have this? chicagokid Engine, Exhaust, Transmission 0 07-21-2014 07:08 PM
Manzo V2 Exhaust Vlady Engine, Exhaust, Transmission 27 03-13-2014 02:02 PM
Manzo Catback Basket Case Engine, Exhaust, Transmission 9 02-25-2014 10:37 AM
