Old 07-22-2014, 03:53 PM   #1
Timmy_Jones
Spun
Drives: 23' Supra
How to install Manzo 2 exhaust?
I am no stranger to exhaust installs and attempted the catback install of my manzo v2 today. All the stock pipes are off fine, however the mid pipe to stock secondary cat has me stumped. I don't think I was given the correct bolts for this as the stock bolts which have springs don't fit, nor does it seem like the donut gasket.
I was given one set of nuts and bolts and those don't fit either....any suggestions? Anyone have this exhaust and installed it yet? Do I need to go buy my own hardware? Do I use the stock donut gasket? I was given two smaller gaskets so I assume the donut gasket is no longer used.
This is similar to the Invidia N1 exhaust if anyone has tips on that install?
Timmy_Jones is offline   Reply With Quote
Old 07-22-2014, 04:57 PM   #2
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
n1 style was hard to put on for me . Muffler goes on first with hanger. then you connect the y pipe to mufflers then have to keep adjusting midpipe and y pipe to get everything in haha.
fantah is offline   Reply With Quote
Old 07-22-2014, 06:34 PM   #3
Timmy_Jones
Spun
Drives: 23' Supra
Yeah it isn't the alignment, it's the bolts not fitting. Bought some new ones. I'll report out tomorrow when I try them out.
Old 07-22-2014, 08:58 PM   #4
fantah
fantah's Avatar
that's lame
Old 07-22-2014, 11:12 PM   #5
kincaid0890
Drives: 2014 FR-S
Had the same problem I just took one of the bolts from the stock mid pipe with me to autozone an matched the bolt. The ones that come with are for aftermarket front pipe because the hole is usually bigger
kincaid0890 is offline   Reply With Quote
Old 07-22-2014, 11:24 PM   #6
kincaid0890
Drives: 2014 FR-S
Old 07-22-2014, 11:30 PM   #7
kincaid0890
Drives: 2014 FR-S
Donut is no longer required. Should have 2 gaskets one for midpipe to front pipe and other for muffler to midpipe
Old 07-24-2014, 08:36 AM   #8
Timmy_Jones
Spun
Drives: 23' Supra
Bought m8 bolts as pictured above. Thanks guys! Exhaust sounds awesome....wish it aligned better, if the rear section was two pieces it would fit perfect.
Old 07-24-2014, 09:16 AM   #9
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Glad you got your Manzo on! I've had my V.2 for a month or so now. Great Sound. I think Manzo is under rated.
What does your fitment look like. Mine took some tweaking to get perfect. Looking at the ass of the car (which is a mighty fine ass) the tip on the right (passenger side) was to the left of the exhaust opening. Is this how yours looked?
GotBRZ1691 is offline   Reply With Quote
Old 07-24-2014, 02:39 PM   #10
kincaid0890
Drives: 2014 FR-S
Yea mine is the same way but u have to stare at it to notice it.
Old 07-24-2014, 03:29 PM   #11
GotBRZ1691
GotBRZ1691's Avatar
Same for me. I need to be like 5 to 10ft away to notice. Any further and its unnoticeable. Have your tried anything to fix it? I was going to jack the rear end of my car up this weekend to see if I can fiddle with the hangers.
Old 07-25-2014, 03:06 AM   #12
kincaid0890
Drives: 2014 FR-S
Honestly no i have not. I've had it on for almost 4 months not noticeable enough for me to worry about it
Old 07-27-2014, 09:33 PM   #13
Timmy_Jones
Spun
Drives: 23' Supra
Yeah, isn't enough to warrant a fix.
Old 08-01-2014, 07:13 PM   #14
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Just ran into the same problem while trying to install @irxproductions exhaust.
Not only did the bolts that connect the Manzo front pipe to the stock overpipe not fit, the exhaust section was touching the rear suspension! Also, the rear tips were crosseyed in the exhaust openings. Had to remove it and I think it will be going back as defective.
OEM bolt won't fit through Manzo front pipe.
Manzo-supplied bolts will not fit through OEM overpipe
Dug around and found some bolts in a drawer that would fit.
Cross-eyed tips look ridiculous
Solid contact between the rear muffler section and the suspension
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
Manzo V2 Exhaust. Anyone else have this? chicagokid Engine, Exhaust, Transmission 0 07-21-2014 06:08 PM
Manzo Catback Exhaust Simon Engine, Exhaust, Transmission 20 07-02-2014 09:44 PM
Manzo V2 Exhaust Vlady Engine, Exhaust, Transmission 27 03-13-2014 01:02 PM
FS: Used Manzo V2 Catback Exhaust (only 40 miles) SOLD Vlady Engine, Exhaust, Bolt-Ons 23 03-12-2014 11:55 PM
