Old 10-01-2014, 02:02 PM   #1
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Shifter issues...here we go
Just got back from a 5 week euro trip, and had been letting my brother drive my car a bit (2013 brz) to keep it from sitting.
I got in it today and jiggled the shifter a bit to make sure it was in neutral, however the shifter will stay to the right side (5th +6th) and not default to neutral in between 3rd and 4th.
This is even more annoying when you're in revered and you pop up the lever to go back to neutral and it gets stuck.
I am running IHE and OFT....so I want to avoid taking it in for warranty if possible.
Anyone else have this issue?
Brahsbrah is offline   Reply With Quote
Old 10-01-2014, 02:13 PM   #2
aagun
Drives: 86
Easy . Just make sure the shifter spring work fine . If not replace http://www.ft86club.com/forums/showthread.php?p=1279044
[ame]http://m.youtube.com/watch?v=Jk8mkTfLANk[/ame]
aagun is offline   Reply With Quote
Old 10-02-2014, 06:49 AM   #3
Brahsbrah
Seems easy enough to do. I guess I'll order the springs and add it to my winter "to do" list!
My only question is what happened to the original springs... I don't see how they could break easily, I guess you never know though.
Old 10-02-2014, 10:24 PM   #4
voivoi
Drives: GT86 TRD Pearl White
Will this job "tighten" the transmission also? After a trackday it became a bit sloppy..
voivoi is offline   Reply With Quote
Old 10-02-2014, 10:34 PM   #5
gramicci101
Off Topic
It will tighten the shifter. Those springs are what make the shifter return to center. The upgraded springs have more pressure returning to center.
Old 10-04-2014, 05:10 PM   #6
voivoi
Thanks!
Old 10-04-2014, 07:08 PM   #7
Dezoris
Dezoris's Avatar
Sloppy loosy goosey feeling shifter after a track day is usually related to trans fluid break down or fluid thinning out.
Old 10-05-2014, 02:19 PM   #8
voivoi
Hmmm.. I should change the transmission fluid also then. But im replacing the springs and busher anyways. What trans oil do you recommend?
Old 10-05-2014, 09:59 PM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
PAO or Ester synthetic - they last longer & unlikely to shear in a hurry.
ZZT86 is offline   Reply With Quote
Old 10-05-2014, 10:43 PM   #10
Dezoris
Dezoris's Avatar
I don't support one brand or another and I don't use this fluid personally but if you are running in a hotter climate and feeling trans get sloppy after track try a fill of Motul GEAR 300 75W90. Takes much longer to get up to temp and stays in grade better than most trans fluids.
Old 10-06-2014, 05:45 AM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
^ I would agree above statement even more so for this particular gearbox so it seems. Recently I ran some Gear 300, initially it was difficult to select 2nd when cold compared to the already sheared down stock oil which had done some 27K kms, temps were still quite cold here in the mornings, but after 2000kms selection improved just like the stock oil did with time - additives pack kicking in ? Currently running the ever popular MTF2 and although I'm finding cold gear selection much improved (not butter), I can't say that I'm 100% happy at this stage (only done 1K kms) when hot as I'm finding gear selection 2 & 3 harsher & more mechanical compared to the cushioned feel of the stock rec oil weight in Gear 300.
It's early days yet but I reckon this gearbox needs the best 75W90 you can get.
Old 06-06-2015, 04:06 PM   #12
Ben_G
Drives: Blue BRZ
So did you get this fixed? I've got just over 50k km on my BRZ and it just started to do exactly the same thing you described when leaving reverse and staying under 5-6. Sometimes I get caught up trying to shift from 2-3 if I don't specifically guide the stick.
Took it to a dealer today and they said that it's "nothing to worry about" and that I should try changing to transmission fluid because "I have high mileage" ???
Ben_G is offline   Reply With Quote
Old 06-08-2015, 12:37 PM   #13
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
What is
IHE and OFT....
Packofcrows is offline   Reply With Quote
Old 06-08-2015, 12:39 PM   #14
gramicci101
Off Topic
Originally Posted by Packofcrows View Post
What is
IHE: Intake, header, exhaust
OFT: OpenFlash Tablet (ECU reflash/tuning)
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Kart boy shifter issues boxer2.0 Engine, Exhaust, Transmission 11 10-25-2014 01:47 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Kartboy Short Shifter Issues Yruyur Engine, Exhaust, Transmission 13 01-27-2014 01:19 AM
