Old 07-18-2014, 02:23 PM   #1
boxer2.0
David W
boxer2.0's Avatar
Kart boy shifter issues
Hey so I just recently installed a kart boy shifter and was wondering if anyone else has had a similar problem. I don't remember noticing and side to side horizontal play when in gear with the stock shifter, but now when I'm in gear I can move side to side almost as much as when I'm in neutral. I have it apart and the shift fork looks as it did when It was stock. Everything points to it being the shifter, and it's not a drive ability issue as it won't come out of gear, but I'm wondering if this happened to anyone else. I have a hard time believing it's the shifter and think it's something I did on the install. any ideas?
Thanks in advance.
boxer2.0 is offline   Reply With Quote
Old 07-18-2014, 02:55 PM   #2
Malt
Drives: 2015 WRX
Thanks in advance.
That side to side movement was there stock. You are just hypersensitive to it now because you are looking for it.
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 07-18-2014, 03:04 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
x2
Old 07-18-2014, 03:05 PM   #4
suaveflooder
Originally Posted by Calum View Post
x2
Yup, both are correct. I had the same thing happen on mine. No different than stock.
suaveflooder is offline   Reply With Quote
Old 07-18-2014, 03:08 PM   #5
boxer2.0
David W
boxer2.0's Avatar
Thanks fellas
Old 07-19-2014, 08:36 PM   #6
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I thought the same when I installed my kartboy, but alas the slop was always there. Try out a friends car for piece of mind.
Mad_Mike is offline   Reply With Quote
Old 07-19-2014, 08:46 PM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I'm curious. Is it really slop?
Old 07-20-2014, 12:07 AM   #8
Squishy
Drives: 2013 WRB BRZ
Yes it was. Note that when most install the short shifter - they are also doing the shifter bushing. This only magnifies the sensation of the slop that the stock rubber bushings hid well.
The MTEC shifter springs address this side to side looseness. But I have not decided if I care enough to do that yet. I just installed my Raceseng Hybrid shift knob which I LOVE over the stock one. Feels great - I like it more than the flossy knob my buddy has as the delrin outer feel matches the kartboy reverse lockout ring feel as well.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 07-20-2014, 01:06 AM   #9
akahenry
akahenry's Avatar
Drives: '18 STi
Is it just me or does downshifting into second with the Kart boy SS seem A LOT harder than with the stock shifter? I've only installed the Kart Boy SS and nothing else, not even the MTEC Springs or rear shifter bushings that came with the Short Shifter. Perhaps if I install the bushings, would I be able to rev-match- downshift into second easier? To restate it, what's the point of the rear shifter bushing?
akahenry is offline   Reply With Quote
Old 07-20-2014, 02:44 AM   #10
Squishy
How long you have it in there? It was tough at first and smoothed out after a couple weeks of use.
The springs are only to make the wiggling of the shifter in the neutral state stiffer and increases resistance when shifting it to the left or right.
The rear shifter bushing makes the whole shifting process much firmer - thus often times the NVH goes up with that bushing installed.
Dale Earnhardt
Old 10-25-2014, 12:29 AM   #11
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Thanks in advance.
I have the same issue. The video shows exaclty what I mean after installing the kartboy shifter.
[ame="http://youtu.be/cAV7SWlGcNU"]http://youtu.be/cAV7SWlGcNU[/ame]
vignesh is offline   Reply With Quote
Old 10-25-2014, 01:47 AM   #12
Squishy
I have a buddy with stock shifter and flossy knob. The slop is there stock. It is masked by the stock rubber rear shifter bushing which is often changed out when installing short shifters.
MTEC shifter springs if you want that gone.
Dale Earnhardt
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Kartboy Short Shifter Issues Yruyur Engine, Exhaust, Transmission 13 01-27-2014 01:19 AM
Red Bull FR-S Go Kart ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 18 05-15-2011 09:49 AM
rollerblade dude vs a Lotus Exige and a shifter kart RRnold Southern California 3 05-05-2011 01:40 PM
