Old 10-01-2014, 11:33 AM   #1
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Dyno in 4th or 5th? 6MT
What's the standard that everyone uses? i know 5th is 1:1 but i'm pretty sure that a 5k rpm pull with 160whp would take about 6hrs... so does everyone dyno in 4th or 5th?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-01-2014, 11:54 AM   #2
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
5th gear. Looking back at the videos on my phone, each run took about 15-20 seconds to get from cruising on the dyno in 5th to redline.
malave7567 is offline   Reply With Quote
Old 10-01-2014, 12:58 PM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
4th
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 10-01-2014, 12:59 PM   #4
D_Thissen
D_Thissen's Avatar
4th is 1:1 if im not mistaken
Old 10-01-2014, 01:46 PM   #5
malave7567
malave7567's Avatar
5th is 1:1 on our close ratio manual 6-speed.
The automatic's 1:1 is fourth gear.
Old 10-01-2014, 02:31 PM   #6
D_Thissen
D_Thissen's Avatar
^^My bad!
Old 10-01-2014, 02:38 PM   #7
malave7567
malave7567's Avatar
Originally Posted by D_Thissen View Post
^^My bad!
it's all good. There has been a bit of confusion between the two. I had originally linked a thread on the forum in my response, but in the first post the OP had swapped the AT and MT labels. It was called out by others in the thread, but still makes a confusing first post.
The Following User Says Thank You to malave7567 For This Useful Post:
D_Thissen (10-01-2014)
Stock Dyno vs GReddy Intake Dyno JTOFJPN Engine, Exhaust, Transmission 0 06-01-2014 04:56 AM
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 03:02 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
