Old 09-28-2014, 05:42 PM   #1
350matt
Drives: toyota mr2/ Toyota GT86
Ecutek Hybrid SD mapping?
Gents
looking into the Ecutek software and you have the option to run a 'hybrid' Speed density option where you use the MAF and the MAP sensor
this seems interesting as I'm presuming that you use the MAF for the off boost NA stuff then switch over to the MAP sensor for the boosted part of the map
is anyone using this and can give some example maps?
As I'm wondering how the handover works with the fuelling ? as you go from tweaking the MAF sensor scale to adjusting the VE map on the speed density?
350matt is offline   Reply With Quote
Old 10-03-2014, 05:50 PM   #2
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Yes, you can run a hybrid speed density mode and you can use MAF on the lower or upper end of the scale. Most often you would tune a hybrid speed density as you describe, using MAF for the lower end and SD for the high end, usually because you are maxing out the MAF sensor.
You can use any combination or any one of MAF, MAP, and RPM to define the switch to SD from MAF. An example would be to use MAF all the way up to close to max MAFv, then switch over to SD from there. You can define the exact breakpoint in the software.
I don't have any example maps, but as long as your MAF and VE maps are dialed in tight, the switchover from MAF to SD is very smooth, seamless I'd say. You can spend a little time at the switchover point to really make it smooth. Fueling would continue just as if it were still running on MAF if tuned correctly.
- Bob
Circuit Motorsports is offline   Reply With Quote
OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes Shiv@Openflash Software Tuning 209 12-28-2022 09:21 AM
hybrid keeps up with brz? youcantseeme24 Engine, Exhaust, Transmission 46 06-02-2014 03:20 AM
Share your Unichip mapping w/mods benlaz88 Software Tuning 19 12-18-2013 02:16 PM
Re-Mapping the ECU Rowdybell Engine, Exhaust, Transmission 4 06-08-2012 09:19 AM
Is it the LFA HYBRID?? Dark Other Vehicles & General Automotive Discussions 6 04-27-2010 09:37 PM
