Old 09-24-2014, 09:39 AM   #1
BRZ888
BRZ888's Avatar
Drives: 2014 Toyota GT86
Euro spec Rear Fog
I finally sourced out the part number that will make the rear fog work just like it came from the factory.
This is for LHD vehicle.
1. Stalk switch with auto feature Toyota SU003-02473 = Subaru 83115FJ110
2. Harness SU003-02576
3. Lens (optional) i opted to buy just because of the factory drilled hole
SU003-02529
4 Relay SU003-02434
First! you need to check if the opposite of the harness has the 3pins. The connector is located at below the trunk lock.
Second, locate the fuse box on the engine compartment check if there is terminals beside the relay of FAN NO.2 Also, a 10AMP fuse.
3rd, once you have these you can order the parts!
BRZ888 is offline   Reply With Quote
Old 09-24-2014, 11:27 PM   #2
Knshro13
Drives: 10 series FRS
We don't have the harness running to the engine bay fuse block in the US. Sucks for us.
Knshro13 is offline   Reply With Quote
Old 09-25-2014, 12:46 PM   #3
WelshJ
Drives: FRS
SU003-02529
4 Relay SU003-02434
If you don't mind me asking, how much for the lens?
WelshJ is offline   Reply With Quote
Old 09-27-2014, 09:41 PM   #4
BRZ888
BRZ888's Avatar
The lens cost $150 just for the genuine cut hole.
Old 09-27-2014, 09:42 PM   #5
BRZ888
BRZ888's Avatar
That really sucks! I am sure BRZ should have it...In your case just modify it.
Old 10-11-2014, 02:54 AM   #6
Heru Farukon
Drives: MOARLOW BEEARRZEE
Pictures?
Heru Farukon is offline   Reply With Quote
Torque spec for rear brake bleeder valve? ddeflyer Tracking / Autocross / HPDE / Drifting 9 08-10-2014 10:38 AM
Anyone have a lead on the euro spec center console? STS-V Cosmetic Modification (Interior/Exterior/Lighting) 9 06-29-2014 02:47 PM
Will the Blitz Nur Spec Cti Quad Exhaust fit with the Tommy Kaira rear bumper?? Inferno7202 Cosmetic Modification (Interior/Exterior/Lighting) 0 05-07-2014 03:47 PM
Euro Lurker - ** EURO Content **youve been warned TheSandeman BRZ First-Gen (2012+) — General Topics 15 07-09-2013 08:11 PM
Nur Spec Rear Wing + Five:AD aero kit mikeg7827 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-19-2012 12:38 PM
