Old 06-01-2012, 12:17 PM   #1
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Early problems - speaker rasp and long turnover
So far I noticed a rasp coming from a front/left dash speaker.
Also, Has anyone else noticed on occasion that it will take a long time to turn over? I've had it take as long as 6 seconds to start.
The Following User Says Thank You to Hawaiian For This Useful Post:
bestwheelbase (06-01-2012)
Old 06-01-2012, 08:00 PM   #2
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Only once did it give me trouble turning over, and that was after I stalled it (damn soft clutch pedal with zero feedback).
No noise from the speakers though.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
bestwheelbase (06-01-2012), Godzilla35 (06-02-2012)
Old 06-01-2012, 08:03 PM   #3
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
The front left speaker on the dash, the plastic part of the speaker holes will pop out of alignment from the dash, it's really annoying. I press it back down, but it keeps popping back out, any suggestions? Anyone else having this problem?
YukiHachiRoku is offline   Reply With Quote
Old 06-01-2012, 08:10 PM   #4
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Ill double check mine tonight, but I dont remember having that.
The only interior part I had to "fix" was the e-brake boot. It wasn't completely snapped into place when I got the car.
Parting out HERE
Old 06-01-2012, 08:29 PM   #5
4U-GSE
Drives: 2013 Scion FR-S MT Ultra Marine
Oh man thanks for saying that! I thought I was the only one. I stalled the car on my test drive today. I couldn't pin point where the clutch engaged. No feedback from the clutch. Mind you this is coming from someone who has a ACT racing clutch and 7.5 lb fly wheel on his current car and hasn't stalled that car in couple years.
At least my FRS is finally here and I'm picking it up tomorrow!
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE
4U-GSE is offline   Reply With Quote
The Following 2 Users Say Thank You to 4U-GSE For This Useful Post:
Godzilla35 (06-02-2012), Snoopyalien24 (07-11-2012)
Old 06-01-2012, 08:33 PM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I have this problem on the passenger side dashboard speaker grill. Take it to the dealership, mines swapping it out under warranty. They said it's an entire 15 minutes of work.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
YukiHachiRoku (06-01-2012)
Old 06-01-2012, 08:33 PM   #7
IceCreamMan
Decepticon
Drives: 2013 Scion FR-S (Asphalt 6MT)
Stalled mine twice the first time I got in it. Very soft clutch compared to what I'm used to. No problems other than wire brackets popping out of the trunk frame when they get hit.
2013 Scion FR-S Asphalt 6MT
IceCreamMan is offline   Reply With Quote
Old 06-01-2012, 08:35 PM   #8
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Same here, I've been stepping on a CM FX300 with an 11lb flywheel for 3 years or so. I can't wait to upgrade the clutch in my FR-S to something with a bit of feedback.
Congrats btw!
Parting out HERE
Old 06-01-2012, 08:38 PM   #9
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
The only rattle I thought I had turned out to be the rear seat back being open. Braked hard and it came open.
blu_ is offline   Reply With Quote
Old 06-01-2012, 08:48 PM   #10
burt
Drives: 2012 Tacoma TRD Sport
When I test drove the FR-S, it took at least 3 cranks to turnover.
burt is offline   Reply With Quote
Old 06-01-2012, 09:34 PM   #11
Lonewolf
Lonewolf's Avatar
Drives: Moped
The hard start/multiple cranks issue sounds like what some people dealt with in the 8th gen Civic.
It turns out that the fuel system needed to be "primed" if the car had been sitting in very cold weather or for several days without being started. The "priming" procedure consisted of turning the ignition to "ACC" while the fuel gauge did a quick sweep and supposedly pressurized the fuel system, at that point you could start without issue every time.
Most people thought the hard start issue was a problem with the battery needing higher cold cranking amps, but it wasn't the case.
The Following 3 Users Say Thank You to Lonewolf For This Useful Post:
adprokid (07-12-2012), Chad86 (12-08-2016), omegared19 (02-13-2013)
Old 06-01-2012, 09:45 PM   #12
Indestruct
Drives: 2013 SWP Limited BRZ, MT
I stalled a couple times too! The engine is so quiet and I can't feel anything from the clutch. I never stalled on my S2k either . Also I had to adjust my heel-toe shifting and rev matching, when I jab at the pedal the rpm's don't jump as fast as I'm used to... feel like a complete shifting noob
Indestruct is offline   Reply With Quote
Old 07-11-2012, 02:11 AM   #13
SF-FRS
Drives: 2013 Scion FRS
I got an alignment issue....the car is pulling right
SF-FRS is offline   Reply With Quote
Old 07-11-2012, 03:04 AM   #14
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Bring it back to the dealer.
Parting out HERE
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 07:18 PM
Popped up dashboard speaker grill Laika BRZ First-Gen (2012+) — General Topics 8 06-21-2012 12:35 AM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 07:41 PM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 05:43 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 12:16 PM
