Old 09-13-2014, 12:47 PM   #1
Andy1814
Drives: 2013 BR-Z
2013 Subaru BRZ, CEL on with no issues
Hi guys, I'm new to the forums.
So I parked my BR-Z inside my garage yesterday and everything was fine, no issues. The later on in the day I went in my car to get my phone I thought I should checked a couple of things. What happened was I put the key in the "on" position and for some reason the check engine light is on, and the radiator fans started to come on briefly and then stop and come on again. I have no idea what is going on here is some information that could help:
It is a 2013 Premium BRZ with 10,000 miles, I check fan relays and replaced them with spares I had. The idle is okay, car drives fine, and their are no known issues besides the CEL, and the fans coming on in the "on" position. I checked if the fans inside the car are on or the A/C and it is not.
Hopefully someone can help me out here!
Andy1814 is offline   Reply With Quote
Old 09-13-2014, 04:04 PM   #2
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Sounds like a dealer trip if you don't have anything to read the code.
ashtray is offline   Reply With Quote
Old 09-13-2014, 04:05 PM   #3
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Did you even start the car? CEL will appear if the engine isnt on. like every car on the planet.
also if your coolant temp is hot enough and your car is in the "on" position the fans will turn on to regulate the heat. Like every car on the planet, regardless if the engine is running or not
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 09-13-2014, 04:06 PM   #4
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Buy a obd2 Bluetooth adapter and buy the torque app to read the code. $13 total.
Old 09-13-2014, 04:15 PM   #5
jflogerzi
jflogerzi's Avatar
+1 and read the code.
Old 09-13-2014, 06:52 PM   #6
Rota
Rota's Avatar
Drives: 2015 Series.Blue BRZ
If you don't want to buy a reader, AutoZone will check your codes for you for free.
Rota is offline   Reply With Quote
Old 09-14-2014, 01:18 AM   #7
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
^this. Why is this something new??
Gords_zenith is offline   Reply With Quote
brz, cel, cooling fan, issue, problem
subaru dealer 1st oil change free? and other issues DarkestBuddha BRZ First-Gen (2012+) — General Topics 19 09-23-2013 02:17 AM
iOS6 + Subaru BRZ bluetooth issues Laika Electronics | Audio | NAV | Infotainment 9 11-20-2012 02:48 PM
Subaru looking into issues with the Nav TSY Issues | Warranty | Recalls / TSB 44 10-04-2012 11:43 AM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 05:02 PM
