Old 09-29-2012, 12:28 PM   #1
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
iOS6 + Subaru BRZ bluetooth issues
Anyone else having a problem getting their iPhone to sync properly with their BRZ after updating to iOS6? Sometimes it will connect like normal within 10 seconds after I start the car. Other times it will fail and then come on a few minutes later. Sometimes it just fails altogether.
I'd just like to figure out if iOS6 is the problem here or if it's something else.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-29-2012, 12:28 PM   #2
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Im having the same problem
Lee358 is offline   Reply With Quote
Old 09-29-2012, 01:08 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Same here
Old 09-29-2012, 01:35 PM   #4
xwd
I haven't really had any issues with the phone syncing, although I'm still trying to figure out why the text messaging doesn't work in my case. I'm assuming you have tried deleting and re-pairing the phone?
Old 09-29-2012, 07:42 PM   #5
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I did. But this time I did a soft reset on my phone and then re-paired it. Seems to be quite a bit better but nothing like iOS5 was. Also, for text messages, as far as I know the Fujituso uses a certain text format that you may seem more commonly on the phones without QWERTY keyboards. This is why you won't see text messages with the iPhone.
Old 09-29-2012, 08:17 PM   #6
Lee358
Lee358's Avatar
With my iphone5 i was seeing the text messages (it got reallly annoying) but now it wont pair every time
Old 09-29-2012, 09:14 PM   #7
Blackforge
Drives: 2013 Subaru BRZ Limited - CBS
I deleted all paired devices from the radio and removed the pairing from my phone. This seemed to help a lot. Still does seem to take a little longer, but before it wasn't even pairing before the radio timed out.
Blackforge is offline   Reply With Quote
Old 09-29-2012, 09:32 PM   #8
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Bluetooth has been a bit flaky with my iPhone 5.
Subie is offline   Reply With Quote
Old 09-30-2012, 10:17 AM   #9
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
I deleted and re-paired. Seems to be better now. And the text notification functions work fine - only thing is, I can't seem to reply using the head unit, it always comes up with an error.
proficience is offline   Reply With Quote
Old 11-20-2012, 02:48 PM   #10
mvhull
Drives: BRZ Limited SSM
How do you delete the bluetooth devices off of the headunit on the BRZ?
I Just upgraded to the iPhone5 and am having some bluetooth issues, messages aren't downloading and connection stalls/fails sometimes. Other times it works fine.
mvhull is offline   Reply With Quote
BRZ Limited Bluetooth Music issues blkwrxwag Electronics | Audio | NAV | Infotainment 14 12-13-2012 05:55 PM
Subaru looking into issues with the Nav TSY Issues | Warranty | Recalls / TSB 44 10-04-2012 11:43 AM
Base FR-S Radio bluetooth synchro issueS! Duff_man Electronics | Audio | NAV | Infotainment 3 08-05-2012 04:36 AM
Anyone having issues with Bluetooth calls and the BRZ. Bg8780 Electronics | Audio | NAV | Infotainment 0 07-21-2012 02:44 PM
BRZ Bluetooth issues? Shizuma Electronics | Audio | NAV | Infotainment 3 06-13-2012 12:06 AM
