Old 09-09-2014, 06:21 PM   #1
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
2000 rpm AT power braking...
Has anyone figured out how to increase the power braking RPM for the Auto trans????
Jaden
Jaden is offline   Reply With Quote
Old 09-09-2014, 07:02 PM   #2
Fast_Freddy
Drives: Passat
Find a higher stall torque converter or send yours out to be modified.
Fast_Freddy is offline   Reply With Quote
Old 09-09-2014, 07:19 PM   #3
Jaden
Road-hole
that's what I was planning on doing...
I'm planning on doing so, I was just wondering if anyone had figured out how to adjust the rev limiter when power braking...It would be nice to keep it, but be able to raise it to 3500 or so...
Jaden
Old 09-09-2014, 07:40 PM   #4
Fast_Freddy
Drives: Passat
AFAIK the rev limiter is set to 7400 rpm. The only "rev limit" when power braking is the TC locking up at ~2000 rpm. Once the tires break loose you can rev to 7400 rpm if you want.
Unless I'm missing something about the stock tune because I had my car tuned very early on, what you want is a high-stall TC that doesn't lock up until 3500 rpm.
Maybe I should be more clear. When I say "lock up" I'm not referring to the electronic TC lockup but rather it's hydraulic stall speed or lock-up. It's not something that can be changed via tuning. The TC has to be internally modified.
Old 09-10-2014, 05:47 PM   #5
FastWhite
Drives: Subaru BRZ Limited M/T
South Side Performance has developed a higher stall converter. Locks up @~3000 rpm.
FastWhite is offline   Reply With Quote
Old 09-14-2014, 08:30 AM   #6
Marusich
Marusich's Avatar
I think he's referring to the Smart Stop "feature", not the TC.
Marusich is offline   Reply With Quote
Old 02-10-2015, 06:17 PM   #7
FastWhite
Here is a follow up on A/T launches. I was seriously looking into the above stall convertor but was holding off on the purchase until after my tune was installed.
I now don't need it.
With the tune and brand new Dunlop ZII StarSpec's I could spin the tire, on launch as much as I needed too. It launched so well that one of the EVO instructors commented on how well it launched. He didn't the car could do that.
I am NA with a skunk 2 CAI, Perrin over pipe back exhaust, 2 1/2". Temperatures was into the low 70's.
Old 02-10-2015, 06:43 PM   #8
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
So what are you guys doing to launch it? Jam the brakes then the gas then just release the brake and go or is there some sort of technique involved?
rattling when braking Latiii Issues | Warranty | Recalls / TSB 14 08-07-2014 12:16 PM
Experience on braking.. tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-29-2013 09:57 PM
first $2000 stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 52 01-18-2013 12:11 AM
Engine Braking Wattage Scion FR-S / Toyota 86 GT86 General Forum 75 01-16-2013 02:51 PM
