Old 09-07-2014, 11:04 AM   #1
briantran123
Drives: fire storm frs 6mt
vortech v2, squeaking noise, gates belt
the car is making a squeaking noise. definitely coming from the belt because me and a master tech tried silicon spray. car didnt like it at all but after work i drove it home and it was gone.... but the next few days it came back gradually.
any ideas? trying to fix the issue now before turning up the boost
could possibly be an alignment issue?
bad belt?
briantran123 is offline   Reply With Quote
Old 09-07-2014, 02:04 PM   #2
Dezoris
Dezoris's Avatar
bad belt?
Probably alignment or tension issue. But most likely alignment.
Old 09-07-2014, 03:16 PM   #3
jkonquer
Drives: 2005 Subaru STI
Most of the time, the squeaky sound comes from the pulley and its bearing. You might have wore out your bearing possibly due to tight belt tension or just wear and tear.
jkonquer is offline   Reply With Quote
Old 12-02-2014, 02:43 PM   #4
Nephilim_Slayer_
i have a similar issue and have been chasing it down for months now. Did you find the problem? new belt, two new idle pulleys and i'm about to replace the alternator. This is starting to really piss me off.
Nephilim_Slayer_ is offline   Reply With Quote
Old 12-07-2014, 11:28 PM   #5
briantran123
havent figured it out yet, been experimenting. the cars my daily and one day i accidentally sprayed silicon spray on the teeth.... squeaking went away. would come back once in awhile. going to figure it out later when i actually have time to take it all apart and inspect. noticing alot of wear and tear. disappointing...
Old 12-07-2014, 11:36 PM   #6
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Really? Master tech sprayed lube on your belt?
Time to order. A new belt
Keep it clean and grease free
I treat that like religion
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-08-2014, 01:46 AM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
This. Try the gatorback belts, I've had good results with mine. The recommended belt shed a lot of rubber dust, the gatorback belt I've got on now is silent and there is much less rubber dusting and the belt looks great.
2013 FRS
Vortech V3 11psi
Old 12-08-2014, 08:48 AM   #8
kiichiro
I'm liking dayco over gator over gates, been thru a dozen belts so far...haven't yet tried the blue...
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 12-08-2014, 12:37 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
I'll have to give the dayco a shot if my gator belt ever decides to skip town
2013 FRS
Vortech V3 11psi
Old 01-26-2015, 10:40 AM   #10
Philly758
Drives: GMC
My kit has been squeaking for some time... Decided to look up the gatorback today and they are on sale for $13.49 on Amazon. Worth a try and figured I would share.
[ame="http://www.amazon.com/Goodyear-4060970-Gatorback-Poly-V-Belts/dp/B000C30J2Y/ref=sr_1_1?ie=UTF8&qid=1422285735"]Amazon.com: Goodyear 4060970 Gatorback Poly-V Belts: Automotive[/ame]
Philly758 is offline   Reply With Quote
Old 01-26-2015, 12:28 PM   #11
DJCarbine
Thupercharged
DJCarbine's Avatar
if you don't have the steel idler pulley I would do it at the same time as the belt swap as added insurance
2013 FRS
Vortech V3 11psi
Old 01-26-2015, 01:06 PM   #12
kiichiro
sorry i liked the plastic one better having run both
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 01-26-2015, 01:47 PM   #13
Philly758
Drives: GMC
I installed a steel pulley a long time ago and I'm not sure if it helped the squeaking. Hopefully this works. It's pretty embarassing.
Old 01-26-2015, 03:13 PM   #14
DJCarbine
Thupercharged
DJCarbine's Avatar
In my case it wasn't a matter of which one to like, as the plastic one failed and the steel is easily found at most parts stores
Did the steel pulley give you problems?
2013 FRS
Vortech V3 11psi
Squeaking noise from the steering ScionFR-S Issues | Warranty | Recalls / TSB 22 02-09-2018 05:37 PM
TANABE FRONT PIPE / MEDALION CATBACK / Omni 2.5 bar map sensor / GATES RACE BELT kinryu Engine, Exhaust, Bolt-Ons 3 08-07-2014 06:01 PM
Squeaking noise from wheel oinkoinkpig Issues | Warranty | Recalls / TSB 8 04-26-2014 11:10 AM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
