Old 09-06-2014, 07:15 PM   #1
mission2toilet
mission2toilet's Avatar
Oil buring smell after installing lighter pulley
I installed kartboy pulley and after brift drive(20min) buring oil smell comes through a/c vent. Anyone had similar problem? Tks
mission2toilet is offline   Reply With Quote
Old 09-06-2014, 08:13 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Check that your install didn't mess up the oring behind the pulley. If it's leaking that may be whats burning.
http://www.ft86club.com/forums/showthread.php?t=26386.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-06-2014, 08:33 PM   #3
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Just did a Perrin pulley earlier today and notice nothing of the sort. As apoc stated check the crankshaft pulley spacer and verify it didn't become unseated.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 09-06-2014, 08:39 PM   #4
mission2toilet
Oring was fine. Never came out or anything.
Old 09-06-2014, 08:50 PM   #5
Apoc
Apoc's Avatar
I would check around the engine below the pulley. If it's all clean you're fine. You may have dripped a bit oil somewhere and it's just burning off.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
mission2toilet (09-06-2014)
Old 09-07-2014, 12:21 PM   #6
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
This, if you're 100% sure the o-ring is fine then make sure the pulley isn't leaking. I have the Perrin and it doesn't leak at all and the Kartboy shouldn't ether. If it does then contact Kartboy for a replacement.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 09-07-2014, 02:26 PM   #7
mission2toilet
Ok, thanks. Its driving me crazy!! I dont see any leak at all..
Old 09-08-2014, 03:38 PM   #8
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
How long have you had thr car for? Mind did this for a bit and then it went away. I have the kartboy pulley as well but I have been smelling something burn, nit sure if it's othrrs cars or mine
Zero90 is offline   Reply With Quote
Should I dyno tests after installing lighter wheels? makesdrivingfunagain Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-10-2014 04:17 PM
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 08:57 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Better to go wider or lighter? BRAWL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-02-2012 09:48 PM
