| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Thanks
Passenger window not going down (reset doesn't work)
I know the issue with frozen windows and to reset it. I tried the reset and it doesn't work.
The car was in an accident. When I dropped it at the shop the windows were working. I pointed it out to the shop and they say take it to subaru they didn't do anything to it. Big fucking coincidence right? Passenger window goes down from passenger door (no auto function). Does nothing from drivers door. Reset doesn't work. What do?
Drives: 13 SWP BRZ Prem
Does the back lighting come on? If not, might have a loose connection behind the door panel.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#3 | |
Thanks
The symptoms tell me it just need the reset sequence. i.e. the window works if you use the passenger side button, but the auto down doesn't you have to hold it. Except the driver side controls aren't flashing like when the windows freeze.
Drives: 2014 BRZ MT (Sold); 2006 V70R
check the connections. it's only a few screws to take off the door panel.
'14 BRZ LTD MT DGM
Car is totaled
Drives: 04' 400whp S2000, 01' DD S2000
Sounds like a common issue scion's have, as this is most likely toyota engineering at work...
I know you said you tried a reset but was it this one? http://clubsciontc.com/forums/diy-in...-computer-673/ If not give it a go
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car) |
#7 | |
Thanks
GOOD! It's a basic security feature, if you had a sun roof that wouldn't have worked either
Believe this may be needed when the battery is disconnected.
Drives: '13 BRZ, '06 997, Other Things(TM)
Did you check the window lock feature / button? I had the same thing happen to me-- someone had just bumped the button and there was zero indication that the window lock was engaged. Try toggling it just for shits.
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 02:14 PM |
| USB port doesn't work | brianc901 | Electronics | Audio | NAV | Infotainment | 2 | 08-15-2014 05:40 PM |
| passenger window reset?? | damaster32 | Issues | Warranty | Recalls / TSB | 3 | 03-25-2014 12:00 PM |
| Passenger Side Window Doesn't Work | JNovo79 | Issues | Warranty | Recalls / TSB | 5 | 02-18-2014 03:14 PM |
| Passenger window not working after rain reset does nothing | Mike86 | Issues | Warranty | Recalls / TSB | 0 | 08-30-2013 08:18 PM |
