Old 09-04-2014, 10:35 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Passenger window not going down (reset doesn't work)
I know the issue with frozen windows and to reset it. I tried the reset and it doesn't work.
The car was in an accident. When I dropped it at the shop the windows were working. I pointed it out to the shop and they say take it to subaru they didn't do anything to it. Big fucking coincidence right?
Passenger window goes down from passenger door (no auto function). Does nothing from drivers door.
Reset doesn't work.
What do?
Old 09-04-2014, 11:32 AM   #2
Imrac
Drives: 13 SWP BRZ Prem
Does the back lighting come on? If not, might have a loose connection behind the door panel.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-04-2014, 11:40 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Everything looks normal. I don't want to start taking things apart yet. I left a voicemail with my adjuster waiting to see what he says.
The symptoms tell me it just need the reset sequence. i.e. the window works if you use the passenger side button, but the auto down doesn't you have to hold it. Except the driver side controls aren't flashing like when the windows freeze.
Old 09-04-2014, 02:12 PM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
check the connections. it's only a few screws to take off the door panel.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-04-2014, 03:40 PM   #5
sklimo
Car is totaled
Old 09-04-2014, 05:21 PM   #6
Darnold
Darnold's Avatar
Drives: 04' 400whp S2000, 01' DD S2000
Sounds like a common issue scion's have, as this is most likely toyota engineering at work...
I know you said you tried a reset but was it this one?
http://clubsciontc.com/forums/diy-in...-computer-673/
If not give it a go
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car)
Darnold is offline   Reply With Quote
Old 09-05-2014, 10:30 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
If not give it a go
haha sweet that worked
Old 09-05-2014, 10:39 AM   #8
Darnold
Darnold's Avatar
GOOD! It's a basic security feature, if you had a sun roof that wouldn't have worked either Believe this may be needed when the battery is disconnected.
Old 09-05-2014, 11:19 PM   #9
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Did you check the window lock feature / button? I had the same thing happen to me-- someone had just bumped the button and there was zero indication that the window lock was engaged. Try toggling it just for shits.
Ganthrithor is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
USB port doesn't work brianc901 Electronics | Audio | NAV | Infotainment 2 08-15-2014 05:40 PM
passenger window reset?? damaster32 Issues | Warranty | Recalls / TSB 3 03-25-2014 12:00 PM
Passenger Side Window Doesn't Work JNovo79 Issues | Warranty | Recalls / TSB 5 02-18-2014 03:14 PM
Passenger window not working after rain reset does nothing Mike86 Issues | Warranty | Recalls / TSB 0 08-30-2013 08:18 PM
