Old 08-31-2014, 11:44 AM   #1
WNDSRFR
Drives: FR-S,GTI
Passenger window not working
OK this is really dumb but maybe it can help someone out who is as dumb as me.
My passenger window quit working today. It doesn't go up or down and the switch is not lit. The same thing happened about six months ago and I had the dealer fix it when he replaced my transmission. I didn't ask what the problem was, I was just happy to have a new transmission and working window.
So, I checked the forum and discovered that the window can be reprogramed by turning ign switch on, engine off, and hold switch down until the window goes down and clicks. Tried it and it didn't do anything.
OK must be a blown fuse.
Checked the fuse under the hood and it's good. WTF?
OK let's bring it to the dealer. I think they're open on Sunday.
So, I get in the car to go to the dealer and think "let me try the programming thing again." Turn on the ignition, hold the switch down and nothing.
Wait a minute......What is that switch above the driver's window switch? It has some kind of weird pictograph of something on it. Looks kinda like a window.
I push the switch and the light on the passenger window switch lights and the window works again.
Oh, that's the passenger window disable switch.
The Following 10 Users Say Thank You to WNDSRFR For This Useful Post:
bcj (06-24-2019), ChrisD (10-23-2016), D-rek07 (10-19-2021), infinity21 (05-20-2016), kch (08-16-2015), q335r49 (01-20-2019), strat61caster (08-16-2015), Suparu (02-24-2020), Ultramaroon (04-07-2017), xxBrun0xx (04-09-2016)
Old 08-31-2014, 03:50 PM   #2
shishand
Drives: Whiteout
lol
shishand is offline   Reply With Quote
Old 08-31-2014, 03:55 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
RTFM
Old 09-01-2014, 12:10 AM   #4
humfrz
Well, at least you "solved" your own "problem" ......
Heck, back in the day, we had it simpler ....... we even had windows that did this ......
humfrz
Atropine (09-01-2014)
Old 09-01-2014, 12:21 AM   #5
litemup
Drives: around
humfrz
That crank is both lighter and more reliable than a motor, reduction gear, associated wiring, switches...
litemup is offline   Reply With Quote
Old 09-01-2014, 12:48 AM   #6
Still not used to the noise the auto up/down makes when I open or close the door. Like Humfrz says in the old days we had cranks and if your window made that noise when you closed the door it meant it just jumped the track. Couple of hours of messing with it meant you were good for a few more months!
Old 03-02-2015, 05:49 PM   #7
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
DONT FEEL STUPID. Im very mechanical savvy, do all my own work no matter what it is. With the exception of lastnight. get in my car and same problem passenger window wont work + no light so i decided to fix it in the morning before work. BOOM, window lock button was activated. #blunted
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 03-03-2015, 01:57 AM   #8
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
LmfaO! I probably would have thought the same thing.....
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-16-2015, 01:14 AM   #9
kch
Senior Misanthrope
kch's Avatar
You saved my ass tonight. I was driving home from dinner with the gf with the windows down. Went to raise them and saw that she had her hand out the window. Panicked and flailed for the window switch and must have accidentally hit this button. I did RTFM when I got the car but must have forgotten 'cause I have no use for that stupid button. Either way, after checking all the fuses and disconnecting the battery, I googled and found you. So thanks.
The Following 2 Users Say Thank You to kch For This Useful Post:
strat61caster (06-24-2019), Tcoat (08-16-2015)
Old 08-16-2015, 02:03 AM   #10
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
hahaHAHAHHAHA
I'm guilty of this too.
Packofcrows is offline   Reply With Quote
Old 08-16-2015, 02:53 AM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
This one time I locked myself in the car...
bcj (11-05-2018)
Old 03-22-2016, 07:18 PM   #12
new2subaru
Weight Weenie
Drives: 15 FR-S
Thank you for the write up!
Now I can reconnect the battery and put the door panels back on...
The Following User Says Thank You to new2subaru For This Useful Post:
ChrisD (10-23-2016)
Old 10-23-2016, 05:55 PM   #13
ChrisD
ChrisD's Avatar
Drives: GT86
This thread literally just saved me from doing the same lol
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
The Following User Says Thank You to ChrisD For This Useful Post:
new2subaru (10-23-2016)
Old 10-23-2016, 05:56 PM   #14
new2subaru
Weight Weenie
Drives: 15 FR-S
Hey, live and learn lol
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 01:25 AM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Passenger Window Sailors14FR-S Issues | Warranty | Recalls / TSB 10 05-04-2014 10:28 PM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 02:50 PM
Passenger window not working after rain reset does nothing Mike86 Issues | Warranty | Recalls / TSB 0 08-30-2013 08:18 PM
