Old 08-30-2014, 03:40 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
How do you check if you have a di seal faliure
Sorry if this has been posted before I searched every way and still could not find the answer I was looking for. I have an avo turbo in my car and I noticed a slight dip from 700-600 rpm while at idle. I also notice popping sound right at start up. What should I look for while data logging.
I am also running the avo base map and an all catless exhaust which makes it hard to pinpoint for any other sounds due to its loud exhaust
Astroboy is offline   Reply With Quote
Old 09-03-2014, 08:10 PM   #2
Astroboy
Astroboy's Avatar
Drives: None
Not one answer...
Old 09-03-2014, 08:24 PM   #3
raven1231
Do about 20 WOT pulls. If engine is still running you're good, if not then you have failure.
Old 09-04-2014, 12:11 AM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
Lol^ is the popping coming from your exhaust or engine bay? If it's only during a cold start I'd think it's just your exhaust. I think the only definitive way is to pull the injectors out. @Dezoris has done it if I remember correctly.
Old 09-04-2014, 02:38 PM   #5
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
You are searching for something that's not there.. If there was a easy way to log that people would have done so a long time ago. There is no way to tell 100 percent if you have di failure with out taking the injectors out to look at them. If you have firecrackers going off under the hood all the time then you need to worry. If its the single pop in the am when the car is 100 percent cold. Don't worry.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-04-2014, 05:32 PM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'd think if you have a defective leaking seal your engine will be exhibiting a lean misfire. A pretty bad one at that. You wouldn't be wondering whether if u have a problem. It would be quite obvious something is wrong. Although I've not experienced a DI seal failure myself *fingers crossed*
Old 09-05-2014, 08:31 PM   #7
86pro
Drives: frs
You will throw a misfire code when they need to be changed. Unfortunately you may not get a warning before you get that code. Best advice see if you smelling out of the exhaust. These cars act funny sometimes when you start up they may pop abit due to not starting for a while. Cold start pops are ok but not pops on a fixed rpm under steady throttle. Thats intake backfire. Our engines actually are built a bit to breath meaning under our FI we need to monitor pressure in the engine. Not a big deal just monitor and if it happens other than idle well you know you got the leak.
hope this helps
86pro is offline   Reply With Quote
Old 09-06-2014, 01:10 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
hope this helps
It's just one single pop right at start up. No idle issues or anything.... wold checking for any signs misfiring in my logs help?
Old 09-07-2014, 08:06 PM   #9
feldy
feldy's Avatar
Mis fires don't mean di issues are exactly the issue. I had mis fire code last November all it was was a coil pack going out. I have not had a single code or issue since.
Old 09-07-2014, 08:14 PM   #10
stugray
Drives: 2013 GBS BRZ Limited
I would say a bleeddown test should show it, but to do that you need to pull the plugs (lift the engine).
Not sure if ive ever heard of anyone doing a BD test on this engine.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Regarding the injector seal issues topazsparrow Engine, Exhaust, Transmission 2 04-04-2014 01:59 AM
diy taillight gasket seal toby714 DIY (Do-It-Yourself) Guides 1 03-10-2014 11:24 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
Nitro seal applied bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 12:22 PM
