Old 08-27-2014, 09:40 AM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
should i flip these R1Rs?
these are 235/40/17 R1Rs that have seen 13 autocross events, I have not yet flipped them and the inside shoulders are still square. (NEW, UNTOUCHED, VERY GOOD CONDITION)
They were not shaved.
I have two events left this season and maybe a single and very short track session.
Was wondering if I should bother to flip them for maximum grip or if there's plenty of tire left on them to keep going?
Is the amount of rubber currently seen in the picture still worthy of competition?
What bothers me the most is that discolored strip above the sidewall. I've not owned R1Rs before so I don't know how they should wear.
Old 08-27-2014, 09:50 AM   #2
chkltcow
Drives: 2013 FRS White w/ cone marks
There are quite a few people I've talked to in the "don't flip street tires" camp. A friend asked a few weeks ago if she should flip hers, and was told "You won't like it." I'd tend to agree as I've driven on Z1s (on my MINI) and Z2s (on an S2000) that were flipped, and both felt REALLY weird afterwards.
chkltcow is offline   Reply With Quote
Old 08-27-2014, 09:58 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
flipped L to R (to maintain grove direction) or just flipped on the rim?
Old 08-27-2014, 10:11 AM   #4
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
You might want to look at the inside edge also to see what is going on in there. You might be able to determine if it is worthwhile then.
I've flipped ZIIs (on my GTI) while maintaining groove direction and had no issue with it, but they were autocross only tires, so I didn't get much distance on them for a proper comparison either.
bimmer635csi is offline   Reply With Quote
Old 08-27-2014, 10:28 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
....as I said, the inside edges are square.. ie, fresh, new, minty, not srubbed. My question is more about whether what's left on this side is still usable or if it's dead.
I've edited my original post so that there is no confusion...
Old 08-27-2014, 11:10 AM   #6
chkltcow
Flipped on rim then moved to the other side of the car to maintain groove direction. I plan on just running mine as-is until they're spent.
Old 08-27-2014, 11:13 AM   #7
vroom4
I drive on all of my autocross tires flipped on the rim and even drive on them backwards so they are pointing the wrong direction. Data shows no difference in tire performance. Its just to save from going to the chords or into a rubber compound that is not very good. (i.e. some of the R1Rs have a 'bad' compound halfway down)
vroom4 is offline   Reply With Quote
Old 08-27-2014, 11:14 AM   #8
vroom4
Kind of blows my mind you are running a 235 r1r on a 7" wheel though
Old 08-27-2014, 11:16 AM   #9
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Honestly, if you want maximum performance....
Replace.
R1R's heat cycle out much faster than other comparable street tires, and yours look like that, and you got them at full depth, those R1R's are probably .5 - .75 of a second off in performance on a 50 second course.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 08-27-2014, 11:30 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Replace.
well, replacement is out of the question since I have nothing to replace them with until spring.
only 2 events left, with one in October.
again my main concern is whether this side right now has usable rubber left or if it's at the limit.
Old 08-27-2014, 12:12 PM   #11
SeanRTR
C-Street AutoX
SeanRTR's Avatar
They looked pretty raped to me. If you're not replacing, I'd flip.
Old 08-27-2014, 12:35 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
The sidewalls of the R1R are pretty soft and while the compound is amazing, they seem to work best when stretched, rather than pinched. I tried the 225/45-17 and got similar results...very accelerated wear on the edges.
simpleisbest is offline   Reply With Quote
Old 08-27-2014, 12:36 PM   #13
vroom4
Exactly.
Old 08-27-2014, 12:40 PM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it was an experiment
plus I didn't want to run into the issue of running into that "bad compound"
i was considering 215's initially, maybe next season.
DIY - Flip Key Fob conversion with pics draggin_az DIY (Do-It-Yourself) Guides 178 05-10-2020 04:34 PM
Switchblade Flip key Mr.Jay DIY (Do-It-Yourself) Guides 23 09-03-2014 11:16 AM
STD 86 Flip Key Ryan86 AFRICA 4 09-30-2013 02:41 AM
Flip Key for my Twin CamryDS Scion FR-S / Toyota 86 GT86 General Forum 38 08-22-2013 04:56 PM
KW V3: To flip or not to flip wootwoot Tracking / Autocross / HPDE / Drifting 40 05-07-2013 05:38 AM
