Old 04-23-2013, 12:55 AM   #1
wootwoot
Drives: FRS
KW V3: To flip or not to flip
I am interested in a set of KW V3's. I know some of you guys are swapping the springs front to rear. I was hoping KW owners could give me some input as to if and why (or why not) you switched your springs. For reference, this car will be a daily driver that will see track duty whenever time and money is available. Hopefully a few times per year. I read on the KW web page that their engineers worked very hard to determine the spring rates and they should not be changed (which I am not sure that I believe).
wootwoot is offline   Reply With Quote
Old 04-23-2013, 01:24 AM   #2
robispec
Drives: Black frs project
lots of experiance with these..
Come by get robispec'ed!
robispec is offline   Reply With Quote
Old 04-23-2013, 01:37 AM   #3
wootwoot
Drives: FRS
lol.. what does that entail?
I am up in norcal. Otherwise I would come to your shop for a chat.
Old 04-23-2013, 01:44 AM   #4
robispec
got LOTS o parts!
Roll center correction for stock front lower control arms
Bump steerable tierod ends
Better than stock KW's
High travel rear topmounts
4 point weld in safety...
BIG radiator and oil cooler single solution.
Robi
The Following 2 Users Say Thank You to robispec For This Useful Post:
CSG Mike (04-23-2013), JDKane527 (04-29-2013)
Old 04-23-2013, 01:49 AM   #5
wootwoot
Drives: FRS
I think I'll PM you.
Anyone else have anything to say about flipping the springs?
Old 04-23-2013, 02:08 AM   #6
Hanakuso
Pics!
Hanakuso is offline   Reply With Quote
Old 04-23-2013, 10:53 AM   #7
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Its a personal preference I think.. I have mine flipped...it just made sense to me.. that the *stronger, higher spring rate goes up front.. I actually have 550lb springs awaiting install ...then the higher KW's might go back on the rear.. got some testing to do.. otherwise.. it would appear to me that the higher Rear rates would cause the Rear to be loose.. havn't tested that theory but it just makes sense.. I am pretty neutral with the higher ones up front.. I am also running a bigger front Bar.. as well as camber plates up front.. Hope that helps.. LMK if you have any more questions..
Bill
Scooby South is offline   Reply With Quote
Old 04-23-2013, 11:10 AM   #8
Racecomp Engineering
On our RCE T2 Clubsports (based on KW clubsports) we start with even rates front to rear. We can customize but for most people the even rates work well. There are a lot of variables to consider so feel free to call or PM us.
- Andy
Old 04-23-2013, 12:00 PM   #9
wootwoot
Drives: FRS
Thanks guys. I know there are many variables here. Tire size and sway bars being two big ones. I'm just trying to figure out where the best place to start is.
Anyone else? Is there anyone that ran them as they come and then flipped?
Also, I see there are some autoXer's here as well as some track guys. How will those different venues effect peoples input?
Old 04-23-2013, 06:04 PM   #10
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
People called me crazy when I suggested running more spring in the front than the rear a few weeks ago. That being said, I'll be swapping the KW Clubsport springs front and rear if the ASTs don't come in first.
GTM_Challenge is offline   Reply With Quote
Old 04-23-2013, 06:43 PM   #11
Scooby South
Conedancer
I have been flipped on mine since I got them.. back last June.... most of the folks I know are flipped.. Not sure why KW made the call to have the higher spring rate in the rear.. makes no sense..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
GTM_Challenge (04-23-2013)
Old 04-23-2013, 06:51 PM   #12
GTM_Challenge
Drives: On track
Bill
Where were you when I need backup? It was all "but the motion ratio this, the motion ratio that" talk. I gave up.
Old 04-23-2013, 06:57 PM   #13
Scooby South
Conedancer
If I would have seen it. I would have backed you up.... sorry man. I know that most of us using the Var 3's for autocrossing are flipped. and that includes some of the other national level builds..
Bill
Old 04-23-2013, 09:10 PM   #14
mrk1
Drives: Sterling BRZ Ltd
I prefer a higher rear rate. No experience with this KW swap but talking in general and in a track setting not autoX
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
DIY - Flip Key Fob conversion with pics draggin_az DIY (Do-It-Yourself) Guides 178 05-10-2020 04:34 PM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 09:24 PM
Driving with slippers/flip-flops/sandals/heels frosty86 Scion FR-S / Toyota 86 GT86 General Forum 58 06-28-2013 08:48 AM
KW suspension Spring flip thought process jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 01-22-2013 11:58 PM
Flip key conversion - Sydney Nytemayr AUSTRALIA 2 01-21-2013 07:05 PM
