Old 08-27-2014, 04:34 AM   #1
Bakemono858
Drives: 2013 Scion FRS
Use stockers for wheel alignment?
Is it okay to use stock wheels for alignment then swap to my new wheels for DD and autocross? My new tire size will be from the top of my head 245/55/17. I've been hearing about people getting damaged wheels after alignments and it's making me really nervous. Sorry if someone finds an old post about this, but I couldn't find anything while on my mobile. Thanks.
Bakemono858 is offline   Reply With Quote
Old 08-27-2014, 08:25 AM   #2
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Yes you can do this without any problem
ToyoburuBRZ is offline   Reply With Quote
Old 08-27-2014, 08:55 AM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I hope you meant 245/40/17
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-27-2014, 08:57 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
If you are putting rally tires on after getting alignment with stock wheels, it might be slightly off
Old 08-27-2014, 10:07 AM   #5
Bakemono858
Haha yes, you are correct
Old 08-27-2014, 10:40 AM   #6
wparsons
wparsons's Avatar
Your alignment won't change, but going from stock wheels/tires to much wider might give you clearance issues at the strut up front. All depends on your wheel offset, how much camber you're trying to get up front, if you're on coilovers or stock diameter springs, and if you're adjusting camber at the knuckle or with a camber plate.
Unless your alignment guy is a hack, they won't damage your wheels at all.
flickr
Tyre/Wheel rotation and wheel alignment for the 86? FT_86_SM_GP AFRICA 17 11-05-2015 04:01 PM
AJ USA Inc. Suspension, Alignment kit, Wheel spacers AJUSA.com Brakes, Suspension, Chassis 16 12-06-2013 01:57 PM
wheel alignment needed? j2digit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 05:32 PM
Wheel works cant do alignment? maxx1957 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-16-2013 09:50 AM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
