Old 02-14-2013, 11:55 AM   #1
maxx1957
maxx1957's Avatar
Drives: red
Wheel works cant do alignment?
Just got back from my local wheel works, they said they cant do my alignment because its not in their computer yet?? Anyone have problems like this? I lowered my car with the eibach prokit, wanted to see how far off it is before I buy some correction parts..
maxx1957 is offline   Reply With Quote
Old 02-14-2013, 01:36 PM   #2
jamal
jamal's Avatar
Drives: Legacy GT
Wow. Find somewhere else. There must be tons of shops in your area that could do a good performance alignment.
jamal is offline   Reply With Quote
Old 02-15-2013, 01:49 PM   #3
frsjon
frsjon's Avatar
Drives: Whiteout Scion FR-S 6mt
I suspect that might be normal for a little while because shops have to update their machines every once in a while for new model cars. i work at a scion/ toyota dealership and our alignment machine does not have the specs for the 2013 scion frs or the new prius C also. hopefully it gets updated soon though.
frsjon is offline   Reply With Quote
Old 02-15-2013, 09:11 PM   #4
maxx1957
maxx1957's Avatar
Drives: red
yeah, went to les schwab today, same thing..lol I guess I'll have to wait a few months..
Old 02-15-2013, 10:34 PM   #5
TemeCal
Drives: 86
If it's just the specs they don't have, why not tell them what you want?
As much camber as you can get in the front, with zero toe
Camber in the back isn't adjustable. Set toe in the rear to .125 toe-in each side for .25deg total toe-in.
I just give my alignment guy the specs I want, and he tries to match it as close as possible.
TemeCal is offline   Reply With Quote
Old 02-16-2013, 12:57 AM   #6
whataboutbob
AutoX-10/10ths every run
I was able to go to my local shop http://alignment-plus.com/ and they did a great job after I installed a bunch of Whiteline stuff and the RaceCompEngineering springs.
Build thread:Here
Old 02-16-2013, 02:53 AM   #7
Dezoris
Dezoris's Avatar
http://www.ft86club.com/forums/showthread.php?t=25001
3rd alignment sheet in that thread has the factory alignment.
If they have a modern hunter, it will have the BRZ alignment sheet to download, its the same thing as FRS.
If not they can load a different car into the machine and then use the specs in that thread.
Old 02-16-2013, 09:50 AM   #8
maxx1957
maxx1957's Avatar
Drives: red
Wow!! Thanks, Just what I needed..
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-09-2012 11:36 PM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
Steering wheel spline / Works bell vendor? NemeGuero Cosmetic Modification (Interior/Exterior/Lighting) 1 10-16-2012 06:43 PM
shop in west Houston for performance wheel alignment hankster Southwest 0 08-21-2012 06:08 PM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 11:41 AM
