Old 08-10-2012, 07:32 PM   #1
simpleisbest
Senior Citizen
Drives: Scion FR-S
RTR Wheel Alignment
I just picked up a set (2) of crash bolts and will look to get a proper alignment next week.
Just want see what suggested alignment settings other RTR people are running (given our restrictions) so far.
Hopefully this discussion could result in some good data as the new sway bar packages, shocks, etc come to market.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
hankster (08-10-2012)
Old 08-10-2012, 10:53 PM   #2
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
As much Camber as you can get in the front, from what I have seen its about -1.2 ... Zero toe
As much Camber as you can get in the rear, which is about -5 or so on the stock springs. .. .125 toe in, for .25 total toe in.
that will pretty much keep the rear end from Skating around.
You might need a bit more...depending on what you like. I tend to like a touch of understeer/neutral handling.
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
simpleisbest (08-11-2012)
Old 08-10-2012, 11:21 PM   #3
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Holy cow, -5 in the rear? Does lowering the car get more in the front?
brz7400 is offline   Reply With Quote
Old 08-10-2012, 11:41 PM   #4
Scooby South
Conedancer
oppsy... meant -.5
not really.. maybe a little bit...I am on coilovers and camber plates...and run -2.5
Old 08-11-2012, 01:11 AM   #5
simpleisbest
Senior Citizen
Drives: Scion FR-S
Thanks! Is the rear adjustable for camber? I thought that with the stock parts the only rear adjustable setting on the rear is toe. If it camber can be adjusted as well that would be very nice!
Old 08-11-2012, 08:02 AM   #6
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I don't believe the rear is adjustable for camber. You need to get the Whiteline rear camber adjustment bushing (kca326). Please someone correct me if I'm wrong.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
The Following User Says Thank You to ft86Fan For This Useful Post:
Old 08-11-2012, 12:58 PM   #7
simpleisbest
Senior Citizen
Drives: Scion FR-S
Thanks but unfortunately, any aftermarket camber bolts are not allowed in the class...
Old 08-11-2012, 02:44 PM   #8
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Using OEM, I got -1.4 out of each front. 0 toe.
Rear is stock camber, .12 toe in each side.
Handles great, set FTD last night at an unclasses fun run autocross.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
hankster (08-12-2012)
Old 08-12-2012, 02:48 PM   #9
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
can any shop that does alignments be able to do this or should a performance oriented shop do this?
hankster is offline   Reply With Quote
Old 08-12-2012, 03:07 PM   #10
#87
I usually post drunk
#87's Avatar
Best bet is independent shop, but tell them what you want before hand and ask if they can do it. Most chain/franchise shops will only align stock hardware and only align to specs in the computer.
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
Old 08-12-2012, 03:16 PM   #11
hankster
hankster's Avatar
I just picked up a set (2) of crash bolts...
this is legal for RTR?
Old 08-12-2012, 04:06 PM   #12
xwd
Yes, it is legal for stock class so it is legal for RTR.
The Following User Says Thank You to xwd For This Useful Post:
Old 08-12-2012, 04:08 PM   #13
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Just did mine yesterday. With the alignment and the car being on Star Specs this car is INSANE. So much fun to drive, I can't wait to take it out next Sunday at my local NYR SCCA autox. You can really tell the difference.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 08-12-2012, 04:25 PM   #14
ft86Fan
ft86Fan's Avatar
Tell us what you did. OEM crash bolt with alignment? What are your settings? Which wheels and what size Star Specs? Thanks.
alignment, rtr, stock class
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 03:25 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
