Old 08-27-2014, 03:54 AM   #1
bunches7399
Drives: 2014 BRZ Limited
OFT Launch Control Install
Just got my OFT, was curious how to implement LC with the E85 tune? I know it's done the OFM and have a good idea how to but I'm pretty new to this and would like some guidance, thanks!
bunches7399 is offline   Reply With Quote
Old 08-27-2014, 07:12 AM   #2
steve99
read OFT TIPS link below its in there
Old 08-27-2014, 08:33 PM   #3
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Get Romraider and the XML File that goes with your car ECU.
Open Rom file with Romraider (Warning may come up where Checksum failed. That's fine just hit OK)
View > User level > 4 (This will allow you to edit the rom file)
Go to last folder that says Alpha FFS/ LC
Set Launch control RPM Delta (Car Max RPM - Your Input = Launch RPM)
Example: 7600 - 2000 = 5600 RPM for Launch Control
Save File
Open OFM
Upload file (You may or may not get warning about checksum, and it'll tell you it's going to correct it)
Yay done, retune your car, have fun
fantah is offline   Reply With Quote
Old 08-27-2014, 08:46 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
I am fairly certain it is already activated on the OTS tunes. With the car fully stopped press the accelerator down and the revs should bounce at about 5600rpm then drop the clutch and enjoy the hours of wheel spin you will have.
1974 TA22 Celica
2013 86 GT
Old 08-29-2014, 06:45 PM   #5
bunches7399
Yall are awesome! thanks for the info!!
Old 08-30-2014, 04:25 PM   #6
bunches7399
Save File
Open OFM
How do i go about getting the XML for my car? i dont want to download the wrong thing and am having some trouble finding everything.
Old 09-03-2014, 09:49 PM   #7
fantah
fantah's Avatar
oft brz website has link
Old 09-04-2014, 07:42 AM   #8
wparsons
wparsons's Avatar
You're going to have to do some legwork of your own. The zip file for the OTS maps contains the XML files, but you need to look up the CAL ID on the OFT (or OFM IIRC) to see which xml file you need. Mine is xxx700C which is an EARLY north american ROM, but yours will be different depending on when you bought the car (and if the dealership has flashed a newer ROM or not) and where in the world you live.
flickr
oft, open flash, open flash tablet
How bad is launch control Bg8780 Engine, Exhaust, Transmission 23 07-09-2014 01:47 PM
Launch Control is back! m.wood0213 Other Vehicles & General Automotive Discussions 0 04-16-2014 12:00 PM
Unichip Launch control SCharged Software Tuning 11 01-22-2014 01:13 PM
visconti tune . launch control. help ft86me Engine, Exhaust, Transmission 5 03-16-2013 07:06 PM
Launch Control on Auto? devinclfalcons Engine, Exhaust, Transmission 28 03-01-2012 07:14 PM
