Old 08-25-2014, 09:45 AM   #1
sammystevan
Drives: Toyota FT86 M/T Black
Question Toda Pulley - Confusing Torque Spec
Hi guys,
I'm just about to install Toda lightweight pulley set. However, when I see the torque instruction, I get a bit confused.
(I am quoting exactly like the instruction).
Tighting torque (Only to be used as a reference)
Crank Pully bolt = 20 N.m (2.04 kgf.m) + 90 deg
Water pump pully bolt = 14 N.m (1.43 kgf.m)
Alternator pully bolt = 108 N.m (11 kgf.m)
I dont understand the "90 deg" part. Could anyone explain it to me?
Thank you so much for the help
sammystevan is offline   Reply With Quote
Old 08-25-2014, 09:56 AM   #2
1Cor10:23
1Cor10:23's Avatar
It means once you get to torque spec, add another 90 degree rotation (essentially quarter turn).
I.e. 360 degrees is a full turn.
Old 08-25-2014, 09:59 AM   #3
SikCee
Pretend Mechanic
Drives: '13 Raven FR-S M/T
http://i.imgur.com/xfhL59l.jpg < Image rightside up
First torque the crank pulley bolt to 20N.m (this seems low)
Second mark the bolt to the pulley
Third tighten the bolt further 90deg this should misalign the markings you have by 90deg
SikCee is offline   Reply With Quote
Old 08-25-2014, 10:23 AM   #4
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Yes 20Nm seems very low for a crank pulley bolt. Typically they are 120Nm. The rest of the instructions look to be correct and very typical for this.
I would call the manufacturer to see if they made an error or you can see if you can find the stock torque spec.
ToyoburuBRZ is offline   Reply With Quote
Old 08-25-2014, 11:14 AM   #5
Akari
Drives: 2013 DGM BRZ
20NM + 90 degrees ends up being pretty high. 120NM + 90 degrees would likely snap the bolt.
Akari is offline   Reply With Quote
Old 08-25-2014, 11:52 AM   #6
ToyoburuBRZ
Drives: Black BRZ
when starting at 20Nm, +90 degrees will maybe get you to 50 to 60Nm which is no where near what you need for a crank pulley.
yes my 120Nm + 90 was exaggerated for this application but is typical of the press in style crank pulleys- I was just trying to make a point that 20Nm was way too low.
Both perrin and raceseng crank pulley installation instructions tell you to go to 94ft.lbs, which, when converted to Nm, is 127.45Nm. I assume this is the factory torque spec. I would use this
Edit:
References:
Perrin: http://www.ft86club.com/forums/showthread.php?t=12583
Raceseng: http://www.raceseng.com/media/pdf/cr...stallation.pdf
Old 08-25-2014, 11:58 AM   #7
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
Edit:
References:
I think you underestimate the amount of additional torque that a 90* rotation would net.
Lawn_Mower is offline   Reply With Quote
Old 08-25-2014, 11:59 AM   #8
1Cor10:23
1Cor10:23's Avatar
Agrees with above, this bolt torques fast past the mid teens. 90 degrees would bring it to spec.
Old 08-25-2014, 08:51 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
I would follow the Toda instructions.
Also @sammystevan please post your impressions of the pully kit and some photos once you have done the install.
1974 TA22 Celica
2013 86 GT
Old 08-25-2014, 09:25 PM   #10
sammystevan
Thanks guys, Adding 90 deg turn makes a lot of sense now.
How about the water pump pully torque? It says 14 N.m without any 90 deg turn, isn't it extremely too low? Even a much smaller alternator pully requires 108 N.m. This just doesn't make any sense
Old 08-25-2014, 10:16 PM   #11
puma
crew chief
puma's Avatar
Drives: Race car FR-S
check out the shop manual, these are the OEM torques
puma is offline   Reply With Quote
Old 08-25-2014, 11:18 PM   #12
sammystevan
Smile
@puma you're right! I just looked it up on brz engine manual, those are indeed OEM specified torque. Thanks a lot, now i'm feeling confidence
pulley toda torque deg
TODA lightweight pulley kit Hanakuso Engine, Exhaust, Transmission 62 04-25-2019 01:04 PM
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 08:39 PM
Alternator pulley torque setting?? ahaghshenas Engine, Exhaust, Transmission 4 07-27-2014 08:03 PM
HELP Raceseng full pulley kit torque setting? Yruyur Engine, Exhaust, Transmission 8 10-16-2013 01:04 PM
Engine Pulley Torque Requirements JDKane527 Engine, Exhaust, Transmission 6 03-22-2013 07:24 PM
