I love peanut butter
Drives: 2013 SWP BRZ Limited
BRZ factory alarm - Able to add sensors?
Does anyone know if the factory alarm system allows you to add a shock\motion sensor? And, is the alarm a separate unit, or is it built into the ECU?
Drives: White 2013 BRZ Limited 6MT
I had the same questions. In asking someone in Japan, the answer I got was a little disheartening. What we have is the Prius alarm system. There is a way to swap out the alarm ecu with one from a Lexus LS, and reflash the stock ecu once the shock sensors have been installed. However, what you'd spend to do so, would be the same cost as what you'd get from an aftermarket alarm with potentially fewer problems.
#3 | |
| sCION fr-s UPGRADED FACTORY ALARM (PROGRAMMED) | mikeg7827 | Electronics | Audio | NAV | Infotainment | 24 | 05-08-2014 04:39 PM |
| Factory Alarm System | Sypher | Northern California | 18 | 03-24-2014 01:23 PM |
| FS: factory TPMS sensors (set of 4) / Muteki Lug Nuts (BNIB) | ZestJDM | Wheels and Tires | 4 | 02-08-2014 02:47 PM |
| FS: factory FRS wheels and tires (TPMS sensors included!) | cb7tuner | Wheels and Tires | 1 | 08-16-2013 12:26 AM |
| alarm wiring help? (using factory remote) | luv85 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-28-2012 07:59 AM |
